Latest: xbluegto
Overall: 3573
Visitors: 132
Total: 132
08: Event Calendar
15: Pictures
44: Event Calendar
66: Pictures
67: Event Calendar
68: Garage
99: Event Calendar
116: My Account
122: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My New Engine
My New Engine
Post Post subject: My New Engine
Posted: Fri Jul 15, 2011 03:55 AM
Build list (so far)
*AS41 case .020 over mains std. thrust, full flow, clearanced, 10mm studs, tapped for oil temp
*Thick walled 92mm AA stroker pistons and liners
*EMPI 82mm forged, CW crank
*Eagle Racing Cam 2242
*Straight cut timing gears
*EMPI 30mm forged lifters
*Scat forged I beam Chevy rods
*Steve Tims Stage I heads and matched ported manifolds
*EMPI dual 44 HMPX 2.0 carbs
*Holley fuel regulator
*EMPI windage tray
*EMPI windage push rod tubes
*Custom length push rods
*Scat 1:1.25 rockers
*Forged 8 dowel lightened flywheel
*Kennedy Stage I clutch
*Doghouse tin and cooler (gonna get powder coated)
* New alternator kit w/welded and balanced racing fan
*1.5 qt. sump
*72 plate oil cooler w/electric fan
Other stuff
*Cut outs to adjust carbs
*New disk brakes (pressed in studs) and EBC Brakes
*A ton of gauges
*Aluminum door panels
**find a way to get new tires**
Post Post subject: Re: My New Engine
Posted: Fri Jul 15, 2011 03:31 PM
Sounds like it will be very quick. You might want to upgrade to CB performance light weight lifters since they are made for thier cams. That is a fast ramp cam and needs very good lifters like CBs light weights or Udo Beckers. If the pushrods are Empi the last set someone brought me to put in their engine were failing in just a few miles. 10 of them failed in less than 25 miles. Get the CB pushrods or the ones Dougs sells. Don't forget the Brad Penn break-in oil.
Posted: Fri Jul 15, 2011 06:16 PM
I got everything from Doug's. Gilbert and Fish helped me make the decisions.
They're not EMPI push rods.
Posted: Fri Jul 15, 2011 08:30 PM
Good the ones they sell hold up and are cheaper than CBs. Your going to like this engine.
crestfallen
crestfallen
Posted: Sat Jul 16, 2011 06:34 PM
It oughta run great! I run AA's in my new 1835 and its done very well so far
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 375 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 960 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 1588 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 1813 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 3947 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
