Latest: bawward
Overall: 3614
Visitors: 112
Total: 112
12: Event Calendar
22: Event Calendar
26: Event Calendar
38: Home
39: Home
41: Event Calendar
42: Event Calendar
45: Event Calendar
46: Pictures
47: Event Calendar
53: Event Calendar
61: Pictures
77: Event Calendar
79: Event Calendar
81: My Account
90: Event Calendar
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 1966 VW Beetle Fuel Sending Unit Removal
jemizasi
jemizasi
Post Post subject: 1966 VW Beetle Fuel Sending Unit Removal
Posted: Thu Apr 28, 2011 03:16 AM
If anyone has experience with the fuel sending unit, I would like to know if it is possible to remove the old one and replace it without removing the tank or the gasoline. Either way I have no idea what to do or where to start but I have a gas leak coming from the unit, and I need some help.
Staff Officers
Posted: Fri Apr 29, 2011 02:10 AM
You can remove the unit from the top of the tank. No need to take the gas out or the tank out. That hard part is getting the float set show it shows full and empty.
jemizasi
jemizasi
Post Post subject: Re: 1966 VW Beetle Fuel Sending Unit Removal
Posted: Fri Apr 29, 2011 05:07 AM
Okay, I got it apart and replaced the gasket. Is there something about how you have to put it back together that could cause the gas indicator to function incorrectly?
Staff Officers
Posted: Fri Apr 29, 2011 05:51 AM
no if you use the same one you are fine. it will only go in one way. the 5 screws are off a little bit so if you can not et it to fit turn it.
I'm talking about a new one.
1 suburbangorilla 4771 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion big beetle 3 bugzapper 3463 big beetle
 Wed Dec 17, 2014 06:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2933 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 5674 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
No new posts VW Volkswagen & Baja Bug General Discussion super beetle baja bug 4 vtbaja 6037 Re: super beetle baja ...
 Wed Aug 14, 2013 04:48 AM
