Visitors: 109
Total: 109
34: Home
46: Event Calendar
60: Home
106: Event Calendar
109: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 65 baja "re" build motor help
H2okuld
H2okuld
Post Post subject: 65 baja "re" build motor help
Posted: Fri Apr 08, 2011 10:39 AM
My motor seems to be seized. We built this car over 20 years ago, but after my sister badly abusing it during her first ten years of driving, it sat for a long time. Well i finally have it back and it's in surprisingly good condition, considering it's neglect. I got it running GOOD for a couple of months before the so called "seizure" occured with just a valve job, oil change, carb rebuild, etc. How can I tell if the motor is truly seized or if I'm missing something? As I said before, it was running and while driving seemed to "brrrrrp" and hasn't ran since. Tries to start, but won't turn over. Battery is good, pulley won't turn by hand. Any advice for this noob is much appreciated as I'm missing my toy. Once motor is running or replaced with something LARGER, this will be slowly built up as a well built desert toy. I'm even willing to trade or possibly pay for labor/ hands on knowledge/ turn key motor.
Thanks
03 Jetta GLI VR6 24v 6sp\r\n99 Jetta Wolfsburg (mkiii) 2.0L\r\n65 baja 1641 irs
4 Admin_AzBaja 5211 Baja Bugs on Wiki need...
1567 mufasavnvmc 854659 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 209172 Re: Baja sightings
Off-road event
1 wideopenmotorsports 357 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
26 1963BAJA 3877 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
