Latest: bawward
Overall: 3614
Visitors: 135
Total: 135
01: Pictures
22: Drivers
31: Home
38: Event Calendar
40: Event Calendar
70: My Account
71: Event Calendar
73: Event Calendar
76: Event Calendar
97: Event Calendar
123: Event Calendar
127: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My project
My project
The following users give thanks for this topic perrib - Thu Jan 26, 2012 09:34 PM
Staff Officers
Post Post subject: My project
Posted: Wed Aug 15, 2012 11:43 AM
Nice big update. Thanks
Posted: Fri Aug 31, 2012 12:47 AM
Well finished welding the rear bumper and frame supports. Got it all painted. Got the headers installed and tail lights all wired. But some coolant in the radiator and would you know it the thing has a leak. Guess thats what I get from the wrecking yard. Pulled out and took to radiator shop for repair. Hope to have it back in a week. More when I get it back.
Posted: Tue Oct 23, 2012 04:55 PM
Time for an update. The old radiator was scraped and installed new one. Got coolant topped off and started. Drove it out of the garage into the drive way under its on power and let it run for 30 min. Never got worm to turn on the fans. I hope that is a good thing. Drove it back into the garage. I ended up wanting to shorten and clean up all the engine wire so it is not running.
Posted: Fri Oct 26, 2012 01:54 AM
That was quite a job. Shortened all the wires that were left going to the pcm. There were 52 of them put all new ends going into the module. Got that done and tried a trip around the block. That was fun a little cold Shocked without the windshield and temp was 42 today. I still need to adjust the shift rod and shifter. Clutch and accelerator work great and it stopped straight, all the things that have been worked on and they work. Laughing
73square
73square
Posted: Fri Oct 26, 2012 03:55 AM
Tons of work there! Looking good!!
That's done - Next!
pepeazul
pepeazul
Posted: Fri Oct 26, 2012 07:03 PM
Looks good!
Where'd you source the wire connectors for the pcm?
Posted: Sat Oct 27, 2012 12:53 AM
pepeazul, I found the best price and quality at Mouser Electronics.
GM wants $1.50 each that was way to much. The ones from Mouser look identical and have the same rating.
Posted: Mon Nov 12, 2012 09:59 PM
Did a little more work on the front end this time. Relocated the fuel pump on a bracket on the front beam. This made it much quieter. Got the spare tire mounted and ready to go.
infuego18
infuego18
Post Post subject: Re: My project
Posted: Thu Dec 06, 2012 04:33 AM
hey im currently building my own baja and ive been wanting to build my own front end and i like urs. I was wondering if you still have the dimensions fr that front end so that i can base mine off of it
Any reply would be really appriciated!
Posted: Thu Dec 06, 2012 06:26 AM
Cant say that I had any measurement. I just went to cutting, grinding and welding. I can put a tape to it and give you some rough measurements.
Give me a couple of days and I will pm you some numbers and other pictures of the build.
Posted: Fri Dec 21, 2012 03:48 AM
Had problems with the motor. It was running rich and would not accelerate. Went back and looked at all the wiring and checked for any vacuum leaks. The Tech 2 that I was should that I was getting random misfires all over the place. I finally pulled the pcm and sent it back to Ryan to have him check his work. Well, it was all good news from there. He had made some changes to the vats when deleting items but was able to correct every thing. So I got it back in and holy cow. This thing really has some get up and go it is almost scary. Now if it would get back up above freezing I would take it out and drive it. I guess I will have to look for a 12 volt heater.
ghettodish
ghettodish
Posted: Fri Dec 21, 2012 05:57 AM
Would it be tough to plumb a heater core to the interior?
Posted: Fri Dec 21, 2012 08:04 AM
I'd use solid copper tubes running the length of the Chassis tube, there should be plenty of room, but my concern would be chafing and leaks.
I guess you could build the heater into just behind the rear seat or underneath near the transaxle and use the existing heater tubes and plumbing for the airflow.
If it were me, I'd go for a factory air unit off of some small car that has a filtered airflow with both an evaporator and heater core so you can do A/C too and maybe simplify the ductwork needed.
It'd be a one off type of thing and a lot of work, but I don't see why it wouldn't be too difficult if you're handy and understand the components and how they work with each other. You'd have to have a Condenser too, but usually they go in front of the Radiator anyways and also have their own fan so you could put it anywhere that it'll get flow.
I'd love to have an air conditioned bug!
Posted: Tue Feb 19, 2013 02:32 AM
Okay, I have got all the windows installed but the back one. What a pain in the a_ _ . Any one have any suggestions on getting it in. I get it in all but the very top and it will not go down and in.
allisontech
allisontech
Posted: Tue Feb 19, 2013 03:34 AM
Your right a real PITA, if you got the windshield in without breaking it your ahead of the game. Weed eater line and clear silicone spray is how mine were installed, crossed over the ends by 8" or so, took some flat hand tapping from a second person outside, and we had to start with the window started all the way around pretty flat. I feel your pain, know a good glass guy?
1199 Dalton 457740 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 5777 Project Purple People ...
88 Dirtjunkie 78694 Project II
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 10679 Re: new project
38 NoKnowledgeCollegKid 28918 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
