Latest: slyster
Overall: 3568
Visitors: 275
Total: 275
19: Home
20: Home
27: Pictures
38: Event Calendar
40: Pictures
48: Pictures
64: Event Calendar
68: Home
95: Event Calendar
117: Event Calendar
124: Event Calendar
127: Pictures
135: Garage
141: Garage
154: Baja Forums
158: Baja Forums
161: Home
168: Baja Forums
171: Baja Forums
173: Baja Forums
177: Baja Forums
179: Baja Forums
184: Baja Forums
186: Pictures
191: Baja Forums
192: Event Calendar
193: Baja Forums
195: Home
196: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Baja Forums
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: Baja Forums
207: Baja Forums
208: AMAZON.com
209: Baja Forums
210: My Account
212: AMAZON.com
213: Event Calendar
214: Baja Forums
216: Baja Forums
217: Baja Forums
218: AMAZON.com
219: Baja Forums
220: AMAZON.com
221: Baja Forums
223: Baja Forums
224: Baja Forums
225: AMAZON.com
226: Baja Forums
227: Baja Forums
229: AMAZON.com
230: AMAZON.com
231: Garage
232: AMAZON.com
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: Baja Forums
237: Baja Forums
238: AMAZON.com
239: Baja Forums
240: Baja Forums
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: Baja Forums
246: Baja Forums
247: Baja Forums
248: Baja Forums
249: AMAZON.com
250: AMAZON.com
251: Baja Forums
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: Baja Forums
257: Event Calendar
258: AMAZON.com
259: Baja Forums
260: Baja Forums
261: Baja Forums
262: Baja Forums
263: Pictures
264: Baja Forums
265: Baja Forums
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: Baja Forums
270: Baja Forums
271: Pictures
272: Baja Forums
273: AMAZON.com
274: AMAZON.com
275: Baja Forums
Baja Forums -:- AzBaja.com Members -:- New Members -:- another newb, just bought my first rail
Post Post subject: Re: another newb, just bought my first rail
Posted: Tue Mar 01, 2011 04:29 AM
Make sure your master set is an Elring made in German as it will come with the good oil cooler and pushrod tube seals.
Posted: Wed Mar 02, 2011 04:01 AM
[quote="Dirtjunkie"]
dogknott wrote:
thanks for the info, I'm almost positive that its swing axle rear with ball joint front.
From the pics we can see its an IRS rear / ball joint front. Looks like a fun Project. Good luck and Welcome to AZBAJA!
In the photo above it appears that you have IRS rear suspension and a late single side plate gearbox which came from VW with a 3.88:1 differential ratio.
dogknott
dogknott
Post Post subject: another newb, just bought my first rail
Posted: Mon Mar 07, 2011 12:59 AM
tore into the motor last night and just as I expected, the rings were broke all to hell in cyl #4, they fell into bout 20 pieces when I pulled the piston out... My big bore kit came in last week so all I need now is gasket kit to throw it back together. Checked with autozone earlier and they can get what they refer to it as "a head gasket kit", it's $25 and from what I can tell it only comes with 1 side, sound right?
dogknott
dogknott
Posted: Fri Mar 25, 2011 07:38 AM
well finally some progress finally!! FINALLY got all my parts in and have started assembling. I ended up going ahead and buying a set of rod bearings while I already had it apart. Hoping to have it all together by end of this weekend and try to get a little trail time on it. I ended up going with just 85.5mm pistons/cylinders for now, but I did find a deal on a set of DP heads with manifolds to use a single solex carb & bought a complete BJ front end with EVERYTHING. It came with ball joints, good tie rods & TR ends, 5 lug wheels/tires, steering stabilizer & even shocks for a $100. And the best part was that the rust is minimal on the new front end I bought, shock mounts have no rust (unlike the ones on the buggy currently) Bought a 6 gallon spun aluminum fuel tank, a set of tires & extra set of polished aluminum rear wheels, set of fiberglass seats. Now really just looking for a set of harnesses an electric fuel pump and a bus tranny, I'm hoping that I'm spending money in all the right places!!
dogknott
dogknott
Posted: Sun May 01, 2011 10:23 AM
well it's been a little while since updating this thread and I'm planning on taking pics of how it sits now, I've been pretty busy to say the least here lately with it!! I bought some aluminum wheels for the rear and got a set of 31x15.5x15 Terra tires cheap but not a lot of life left on them. Swapped out my wore out 4 lug front end for a wide 5 complete front end in better shape, re-done all of the wiring and made a stainless overhead switch panel for ignition, lights and horn. I bought a 3 rib bus tranny a month or so back and just now got it in and going. So to make a long story short a few of us went on a ride yesterday afternoon and I was psyched to try out the new tranny and it done great for 2 hours or so and well hopefully someone reading this can help me diagnose the problem that's occured. I was in 1st gear crossing a creek and clutched it to shift into 2nd and it wouldn't go in. shifter rod feels all out of wack but has all new bushing and the piece that attaches near the nose cone. it's stuck in 1st gear but by looking at the placement of the shifter it looks to be in 2nd gear. One of the guys I was riding with said he had it happen to him one time and it was a pin in the nosecone assembly or something that has a tendency to fall out and the way he explained it, it's what attaches to the shifter rod. Is this a common problem and how exactly can I go about fixing it? I'm pulling the motor/tranny in the morning so that I can get a better look and so I can pull nosecone cover off. Any help would be greatly appreciated!!
Posted: Sun May 01, 2011 05:13 PM
Before you pull parts disconnect the shift rod and leave the coupler attached to the transmission and see if you can get the gears.
dogknott
dogknott
Posted: Mon May 02, 2011 04:54 AM
I just loosened the mounts and slid the motor/tranny back enough where I could remove nose cone and sure enough I got lucky enough that the pin on the inside had slid out. Whew!!! Thank god!!
Posted: Tue May 03, 2011 03:37 AM
Glad to hear it was a cheap and easy fix.
dogknott
dogknott
Posted: Sat May 07, 2011 08:46 AM
a few quick pics I snapped tonight of how it currently sits. It's nasty as hell but has come quite a long way from the first pics I posted. Still need one more seat cover for passenger side...(drivers side was free!! Just couldn't find the other one
dogknott
dogknott
Posted: Mon May 09, 2011 09:02 AM
well just when I thought I had solved my transmission issue, its doing some ignorant sh*t now.... Took it back out yesterday after fixing it to try it out and it done great for around 2 hours or so and then I thought it had done the same thing again inside the nosecone. It was stuck in 1st gear again and I limped it back to the truck. Took the nose cone cover off of it when I got to the garage expecting to see that the pin had somehow fallen out again but not that lucky. Instead intermediate shift lever somehow got in behind the 1st/2nd gear selector shaft, if that makes any sense to you. Once I had the nose cone cover off it took bout 2 seconds to pop the hockey stick out of the way and push the 1st/2nd shaft in. I put it back together and in no time it's done it again!!! What would cause this to happen? I'm thinking that the shifter/shifter rod is way out of adjustment and it's allowing some over-travel on the intermediate shift lever letting it get wedged behind the 1st/2nd shaft. Any help would be greatly greatly greatly appreciated!!!
dogknott
dogknott
Posted: Tue May 17, 2011 08:58 AM
anyone???
Posted: Thu May 19, 2011 05:01 AM
You must have a lot of slop in the shift rods and they move apart far enought to move out of thier slot.
dogknott
dogknott
Posted: Thu May 26, 2011 06:43 AM
I still haven't figured it out but I've narrowed it down to either the shift rod itself or that it didn't have a reverse lockout plate and it was somehow allowing it to be going between gears.... But on a lighter note I ended up with a new buggy that I'll be posting pics of here shortly (if it ever quits raining here...) 102" wheelbase, spindle mount wheels, 15x12's on rear with V treads, 3 rib bus, 1641cc with DP heads, aftermarket cam, 2 barrel carb, electric pump, etc...
siacs
siacs
Posted: Thu May 26, 2011 12:09 PM
Lets see the pictures
dogknott
dogknott
Posted: Wed Jun 15, 2011 07:48 PM
heres a few pics of the new rail on a recent trip to Brimstone Recreation in Huntsville, TN
No new posts New Members I'm a newb. 10 Yasha7fold 1209 I'm a newb.
 Tue Jul 18, 2017 03:57 PM
No new posts Projects and Builds bought a turd…. better get out the polish!
been a while...
7 acousticrawk 4859 bought a turd…. bett...
 Sun Jun 22, 2014 11:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion My VW Rail vacation 13 azdesertrat87 5486 Re: My VW Rail vacatio...
 Mon Jul 22, 2013 07:32 PM
No new posts New Members Bug Newb
New to Airchilled VW's
5 Volksx2 3221 Bug Newb
 Fri Sep 14, 2012 09:54 PM
No new posts New Members Newb - Now With Pictures! Woohoo!
19 thing 9880 Re: Newb - Now With Pi...
 Tue Aug 21, 2012 06:04 AM
thing View latest post
