Latest: BlackIrish05009
Overall: 3574
Visitors: 135
Total: 135
24: Pictures
39: Event Calendar
40: Event Calendar
46: Event Calendar
68: Event Calendar
85: Pictures
87: Event Calendar
118: My Account
129: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- newbie electronic distributor ?
albcole92
albcole92
Post Post subject: newbie electronic distributor ?
Posted: Thu Feb 24, 2011 08:05 AM
i was just wondering i have a vac advance distributor i want to go to the centrifugal 009 electronic ignition system what would i have to buy to to make it work anything extra that i dont already have for my vacuum distributor ?
66 baja bug
70 fastback
Post Post subject: Re: newbie electronic distributor ?
Posted: Thu Feb 24, 2011 09:38 PM
I believe all you have to do is buy a 009 centrifugal dist., install then block off the vacuum line from it's source. Installation is pretty much an even swap.
albcole92
albcole92
Posted: Thu Feb 24, 2011 10:26 PM
thanx i think i am going to buy the empi 009 distributor with the electronic pick up. alredy installed i was just wondering if i needed to add anything to my coil or anything cuz on the ad it says must be used with an eternal resistor or external ballast how do i know my coil has one ?
66 baja bug
70 fastback
No new posts New Members The new newbie 3 carpermike20 1883 The new newbie
 Thu Oct 08, 2015 08:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion newbie needs help! 2 iwannabajabug 1829 Re: newbie needs help!
 Thu Jul 24, 2014 12:36 AM
iwannabajabug View latest post
No new posts New Members Newbie from Washington State
1972 VW Baja
18 ButchW 8188 Newbie from Washington...
 Sun Jan 19, 2014 03:50 PM
ButchW View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Water proofing distributor
Heat shrink?
3 ButchW 2241 Re: Water proofing dis...
 Wed Oct 02, 2013 04:00 PM
No new posts New Members Newbie from "florduh" here. Mid travel build. 9 shawn813 3904 Newbie from "florduh"...
 Thu Apr 18, 2013 11:13 PM
shawn813 View latest post
