Latest: strike77
Overall: 3575
Visitors: 138
Total: 138
05: Event Calendar
16: Event Calendar
19: Event Calendar
20: Event Calendar
27: My Account
40: Event Calendar
48: My Account
77: Event Calendar
84: Event Calendar
89: Home
98: Event Calendar
99: Event Calendar
127: Event Calendar
133: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Suspension
Suspension
Cooop!
Cooop!
Post Post subject: Suspension
Posted: Wed Jan 12, 2011 09:08 PM
I'm getting a 6" wider 10" tower Warrior beam off my bro, He had it on a baja bug he bought and eventually had to buy another car due to rust and what not. Anyway we were out at California city and he couldnt get the ride any softer...took off the shocks and tried to adjust the beam...still so stiff you could stand on it and it wouldnt give, so im thinking the adjusters are bad or something very minor is wrong. The beam isnt very old at all. And Im sure he got It from CB performance down the street lol Id really Appreciate it if someone could give me advise! My bug is under baja bugs as helga from cooop! lol
Real deal neil from Farmersville
Posted: Wed Jan 12, 2011 09:49 PM
Try removing the top leaves and replacing them with a through rod. My bro did that on his fiberglass buggy and it made a huge difference.
Posted: Fri Jan 14, 2011 09:59 AM
It may be that the trailing arm bushings are not properly reamed and the arms are tight in the bushings.
ikill6453
ikill6453
Post Post subject: Re: Suspension
Posted: Fri Jan 14, 2011 04:57 PM
i had to have the bushings in my warrior front end reamed out, i took it down to my local buggy shop and they mic. the trailing arms shaft and then mic. the inside of the bushings, and used a tool to shave off evenly the inside of the bushing till it fit better. made all the differance in the world. ton of movement, and still tight front end.
Posted: Fri Jan 14, 2011 04:58 PM
That was my first thought too. I have seen too many people buy the wrong bushings and force the arms in the beam and this is the result. Stay away from the empi bushings they are JUNK and too soft, the bug pack bushings are urethane and available in several sizes and work fine for most applications and run $30-$35 a set. If you want really good bushings go to the SACO delrin bushings, they are about $60+ a set.
If you need help getting the correct ones PM me.
No new posts Projects and Builds Suspension Help 5 RDMINAZ 3637 Suspension Help
 Mon Jul 18, 2016 03:06 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja suspension upgrade on All Girls Garage TV show May 3rd. 4 BugZyla.com 4422 Baja suspension upgrad...
 Tue May 13, 2014 12:35 PM
irs,swingaxle
3 desertbaja 2894 Re: 1968 vw beetle rea...
 Tue Aug 28, 2012 04:37 PM
No new posts VW Volkswagen & Baja Bug General Discussion Rear suspension question 5 FLBaja 3707 Rear suspension questi...
 Tue Jul 26, 2011 12:08 AM
No new posts Projects and Builds Chris from Vegas suspension upgrade.
21 BugZyla.com 14098 Re: Chris from Vegas s...
 Wed Jul 20, 2011 07:05 PM
Ejbbal21 View latest post
