Latest: xbluegto
Overall: 3573
Visitors: 191
Total: 191
18: My Account
63: Event Calendar
89: Pictures
113: Home
114: Event Calendar
131: Home
142: Home
143: Pictures
147: Home
150: Event Calendar
154: Baja Forums
158: Baja Forums
162: Baja Forums
168: Baja Forums
170: Baja Forums
172: Baja Forums
178: Baja Forums
184: Baja Forums
187: Baja Forums
190: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What size battey?
What size battey?
bajaboi727
bajaboi727
Post Post subject: What size battey?
Posted: Fri Dec 24, 2010 01:19 AM
What size battery do you guys reccomend/ run? The one in my car is only 400 cold cranking amps, and turns pretty slow so I'm going to the parts store this weekend for a new one.
Post Post subject: Re: What size battey?
Posted: Fri Dec 24, 2010 03:06 AM
Group 42 is the original size about 500 cca. Get yours load tested all the starter needs is about 180 amps. If yours holds a load your trouble is else were.
Posted: Fri Dec 24, 2010 04:14 AM
I was told that if you have a body lift, there are no restrictions on your battery size because the reear seat sits 3" higher.
Posted: Fri Dec 24, 2010 04:58 AM
Thats true an MB 88 (about 80 plus pounds) would fit in a large marine battery box. A battery box is a great idea. Unless your using an Optima style battery you get to watch the acid drip out onto the headliner when you roll over.
ikill6453
ikill6453
Posted: Fri Dec 24, 2010 06:09 AM
i would like to suggest the optima battery ... on sale you may find it for 150.00 bu if you ever need it to get you out of a bind it will do the job with no worry.
the one in my rail is over 4 years old... i run most weekends and about a month ago, i left my lights on in the rail sitting in my driveway, got a phone call, and came back to the rail about 3 hours later.... it cranked up and ran great. i have a red top and love it. no worries.
bajaboi727
bajaboi727
Posted: Mon Dec 27, 2010 09:44 PM
Yeah, we've got a red top in the cobra, which does more sitting than driving and its great. and the old one didnt hold a charge... so im going now to pick one up. I'm not going to spend the money for a red top in the baja, just a simple battery will do. I'll see what i find Smile
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 1880 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What size are fender bolts? 2 az350x 2268 Re: What size are fend...
 Thu Dec 02, 2010 11:30 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion what size motor do you have in your baja 12 mccolery5 10444 Re: what size motor do...
 Wed Dec 02, 2009 05:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion tire size 3 cyberjaw4 1681 Re: tire size
 Sat Feb 07, 2009 05:36 AM
No new posts VW Volkswagen & Baja Bug General Discussion Exhaust size 2 XXJUPITERXX1 1044 Re: Exhaust size
 Sat Oct 13, 2007 01:41 PM
vwbill View latest post
