Latest: ecthemc
Overall: 3567
Visitors: 170
Total: 170
53: Event Calendar
77: Pictures
115: Pictures
127: Pictures
146: Event Calendar
166: Pictures
Baja Forums -:- AzBaja.com Members -:- New Members -:- Bigsulu
Bigsulu
Bigsulu
Bigsulu
Post Post subject: Bigsulu
Posted: Sat Jul 14, 2012 12:34 PM
Found az searching for new beetle lift. I live in North Dakota. I need extra clearance for winter. I found a metanerd lift but would like to upgrade suspension. I'm wondering if there is a kit to lift without using blocks.
Bugs are manly
Post Post subject: Re: Bigsulu
Posted: Sat Jul 14, 2012 04:11 PM
Welcome to AzBaja. CFIf you have already lifted the stock suspension as high as it can go, use raised front spindles, in the back use 930 or t-4 cvs and notch your rear spring plates until thev rear axles are angled up to 22-24 degrees, notch them until the rear is as high as the front. Now would be the time to upgrade to a 4.88 T-1 rp or a 3 rib T-2 transmission with a nice 5.36 rp.
Posted: Sat Jul 14, 2012 07:01 PM
welcome to the site we like to see pictures
Posted: Sun Jul 15, 2012 07:16 AM
Take note here guys...He's talking NEW Beetle. Different breed of animal.
Posted: Mon Jul 16, 2012 03:44 AM
Darn I thought he meant new to him. Raising a New Beetle you could relocate the lower suspension mounts and the move the sring and stut mounts down to compensate.
Posted: Mon Jul 16, 2012 08:00 AM
welcome to the site.
Posted: Fri Jul 20, 2012 05:52 AM
Where my son works they built this New Beetle.
That's a couple of blocks over at Crumco.
They are working to get a new offroad race class going using New Beetle bodies.
The car pictured above was featured in Hot VWs last year. My son helped to re-body this one last December after it got endoed at about 100mph while out in the Desert near Barstow to watch a MORE desert race. The body is a VW New Beetle steel body with a carbon fiber front clip. The chassis is chrome moly tube and plate-fabricated box section. The drivetrain is a 400+hp Honda V6 mounted mid-engine with a Weddell trans behind it. The a-arm front suspension is pretty much the same as what Class 1 desert race cars use and the rear is also Class 1 full trailing arm.
If you want an offroad worthy New Beetle, call Crumco. They can put one together for you pretty much however you want it or can afford it, long as it's feasible.
But don't think you can pick up lift kits for them most anywhere. Nobody is manufacturing anything of the sort.
