Latest: BlackIrish05009
Overall: 3574
Visitors: 118
Total: 118
37: Pictures
46: Event Calendar
66: My Account
86: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- carb troubles
carb troubles
vwbajabug1
vwbajabug1
Post Post subject: carb troubles
Posted: Tue Nov 09, 2010 12:41 AM
i have a 34 pict 3 carb that i got rebuilt a couple of days ago. i replaced the bushens my self and its still doing the same thing that it was doing before i got it rebuilt and everything. could some one tell me what mite be wrong with it before i go and buy a new one...
Thanks Confused
WILDMAN
Rickman
Rickman
Post Post subject: Re: carb troubles
Posted: Tue Nov 09, 2010 11:33 PM
First...Welcome to AzBaja.com!
You will need to provide some more information before you will get any useful responses.
What was/is your carb doing. What are you trying to fix?
vwbajabug1
vwbajabug1
Posted: Wed Nov 10, 2010 10:44 PM
it want stay idled even when im adjusting it
WILDMAN
bajaboi727
bajaboi727
Posted: Wed Nov 10, 2010 11:21 PM
check the idle solenoid, should be sticking out of the bottom left side of the carb, pull it out and make sure it's not bent, or gummed up.. than put power to it, you should see the shaft move, if not... THAT IS YOUR PROBLEM.. had the same issue with my 34 pict3...
vwbajabug1
vwbajabug1
Posted: Thu Nov 11, 2010 02:13 AM
thanks i will check but.... i put a new one in. the carb was cleaned when it got it rebuilt and almost every thing is new on it
WILDMAN
bajaboi727
bajaboi727
Posted: Thu Nov 11, 2010 02:27 PM
If you just bought a rebuild kit, the kits don't come with them.. it's the little thing with the wire sticking out of the left side of the carb.
vwbajabug1
vwbajabug1
Posted: Fri Nov 12, 2010 12:26 AM
o sorry got mixed up with something else. i will check it
WILDMAN
Posted: Fri Nov 12, 2010 04:13 AM
Welcome to AZBAJA. Smile No pictures of your ride. Shocked www.robertbentley.com/volkswagen/ You really need the 1970-1979 VW factory manual or a used copy. This can also help you.
www.vw-resource.com/34pict3.html. While not your trouble this crab works best with preheat and the correct distributor.
www.aircooled.net/new-...1&cartid=. Your best bet is to try and find a good used one not easy but it can be done.
vwbajabug1
vwbajabug1
Posted: Sat Nov 13, 2010 12:44 AM
the pics are on my other post called bajabug
WILDMAN
Posted: Sat Nov 13, 2010 07:02 AM
I'll take a look. Any word on your carb troubles??
vwbajabug1
vwbajabug1
Posted: Sun Nov 14, 2010 02:17 AM
found some differnt types of carbs. im going to try them out 2maro. didnt have time today been fishing at lake murry.. all day..CATFISH.. i will let yall no how it goes
WILDMAN
vwbajabug1
vwbajabug1
Posted: Mon Nov 15, 2010 03:12 AM
i got a weber 5200.. i put it on and ran it today some and im going to get a tune up kit for it... it hasn't seen a car in about 9 years. so good so far. better than the 34 pict 3.. (^^^)
WILDMAN
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 1818 Re: Carb Intake Covers
 Wed Jan 11, 2012 12:46 AM
Gunpilot View latest post
No new posts Projects and Builds wanting 34 pict-3 carb
i need a carb
0 vwbajabug1 1475 wanting 34 pict-3 carb
 Tue Nov 09, 2010 01:07 AM
vwbajabug1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion carb 9 luhrman645 3553 Re: carb
 Wed Aug 04, 2010 10:47 PM
No new posts VW Volkswagen & Baja Bug General Discussion Please Help I need a carb expert
Help Help Help
3 Ejbbal21 1902 Please Help I need a c...
 Thu Feb 25, 2010 06:57 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb and intake setup? 11 Torg37 6031 Carb and intake setup?
 Fri Feb 05, 2010 04:26 AM
