Latest: jamlip
Overall: 3581
Visitors: 181
Total: 181
03: Pictures
10: Home
13: My Account
14: Pictures
27: Home
85: Event Calendar
90: Event Calendar
122: Pictures
127: Event Calendar
150: Baja Forums
152: Home
168: Baja Forums
170: Baja Forums
178: Baja Forums
181: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- carb troubles
carb troubles
vwbajabug1
vwbajabug1
Post Post subject: carb troubles
Posted: Mon Nov 08, 2010 11:41 PM
i have a 34 pict 3 carb that i got rebuilt a couple of days ago. i replaced the bushens my self and its still doing the same thing that it was doing before i got it rebuilt and everything. could some one tell me what mite be wrong with it before i go and buy a new one...
Thanks Confused
WILDMAN
Rickman
Rickman
Post Post subject: Re: carb troubles
Posted: Tue Nov 09, 2010 10:33 PM
First...Welcome to AzBaja.com!
You will need to provide some more information before you will get any useful responses.
What was/is your carb doing. What are you trying to fix?
vwbajabug1
vwbajabug1
Posted: Wed Nov 10, 2010 09:44 PM
it want stay idled even when im adjusting it
WILDMAN
bajaboi727
bajaboi727
Posted: Wed Nov 10, 2010 10:21 PM
check the idle solenoid, should be sticking out of the bottom left side of the carb, pull it out and make sure it's not bent, or gummed up.. than put power to it, you should see the shaft move, if not... THAT IS YOUR PROBLEM.. had the same issue with my 34 pict3...
vwbajabug1
vwbajabug1
Posted: Thu Nov 11, 2010 01:13 AM
thanks i will check but.... i put a new one in. the carb was cleaned when it got it rebuilt and almost every thing is new on it
WILDMAN
bajaboi727
bajaboi727
Posted: Thu Nov 11, 2010 01:27 PM
If you just bought a rebuild kit, the kits don't come with them.. it's the little thing with the wire sticking out of the left side of the carb.
vwbajabug1
vwbajabug1
Posted: Thu Nov 11, 2010 11:26 PM
o sorry got mixed up with something else. i will check it
WILDMAN
Posted: Fri Nov 12, 2010 03:13 AM
Welcome to AZBAJA. Smile No pictures of your ride. Shocked www.robertbentley.com/volkswagen/ You really need the 1970-1979 VW factory manual or a used copy. This can also help you.
www.vw-resource.com/34pict3.html. While not your trouble this crab works best with preheat and the correct distributor.
www.aircooled.net/new-...1&cartid=. Your best bet is to try and find a good used one not easy but it can be done.
vwbajabug1
vwbajabug1
Posted: Fri Nov 12, 2010 11:44 PM
the pics are on my other post called bajabug
WILDMAN
Posted: Sat Nov 13, 2010 06:02 AM
I'll take a look. Any word on your carb troubles??
vwbajabug1
vwbajabug1
Posted: Sun Nov 14, 2010 01:17 AM
found some differnt types of carbs. im going to try them out 2maro. didnt have time today been fishing at lake murry.. all day..CATFISH.. i will let yall no how it goes
WILDMAN
vwbajabug1
vwbajabug1
Posted: Mon Nov 15, 2010 02:12 AM
i got a weber 5200.. i put it on and ran it today some and im going to get a tune up kit for it... it hasn't seen a car in about 9 years. so good so far. better than the 34 pict 3.. (^^^)
WILDMAN
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 1981 Re: Carb Intake Covers
 Tue Jan 10, 2012 11:46 PM
Gunpilot View latest post
No new posts Projects and Builds wanting 34 pict-3 carb
i need a carb
0 vwbajabug1 1572 wanting 34 pict-3 carb
 Tue Nov 09, 2010 12:07 AM
vwbajabug1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion carb 9 luhrman645 3883 Re: carb
 Wed Aug 04, 2010 10:47 PM
No new posts VW Volkswagen & Baja Bug General Discussion Please Help I need a carb expert
Help Help Help
3 Ejbbal21 2005 Please Help I need a c...
 Thu Feb 25, 2010 05:57 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb and intake setup? 11 Torg37 6566 Carb and intake setup?
 Fri Feb 05, 2010 03:26 AM
