Visitors: 127
Total: 127
03: Event Calendar
04: Home
21: Pictures
27: Event Calendar
38: Event Calendar
41: Pictures
42: Pictures
45: My Account
60: Event Calendar
77: Event Calendar
84: Event Calendar
100: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- QUESTION AND SUGGESTIONS
bugzapper
bugzapper
Post Post subject: QUESTION AND SUGGESTIONS
Posted: Fri Oct 15, 2010 03:29 AM
I might pick up a bug here from so.mn its a 74 i believe. its a fuel injected rather clean (for mn anyway) -- what are some advantages and disadvantages of the fuel injection? are the fenders worth selling or should i just cut them? my freind says hes got a supercharger that'll work on it is this a good idea?/will a supercharger work?
OR- if the bug is really as clean/solid as it seems am i better off selling it as original inted of baja'ing' it
"killing time isnt murder -- its suicide"
bajaboi727
bajaboi727
Posted: Fri Oct 15, 2010 04:27 PM
If it's a 74 and fuel injected, It's probably a super beetle. Which have different suspension, and are not really worth baja'ing unless you have some serious cash...
Post Post subject: Re: QUESTION AND SUGGESTIONS
Posted: Sat Oct 16, 2010 01:24 AM
Fuel Injection was introduced for 1975. FI helps a VW engine last longer if you make it a Baja you might just want to shorten the Deck lid not eliminate it. Fenders fit 73-79 so they are worth saving if they are not damaged. A super uses struts so it is easy to identify.
bugzapper
bugzapper
Posted: Sat Oct 16, 2010 02:15 AM
Thanks guys, Ill check it out again. so ur saying there is a chance that it could be a fuel injected non-super beetle?---IF this is the case what should I do??
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 7920 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2657 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5476 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3455 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4375 super baja question
 Thu Aug 29, 2013 11:07 PM
