Visitors: 117
Total: 117
22: Event Calendar
28: Event Calendar
36: Pictures
50: My Account
56: Home
60: Event Calendar
90: My Account
103: Event Calendar
115: My Account
116: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Any hints on removing the body on my 1970 Bug?
Ken48442
Ken48442
Post Post subject: Any hints on removing the body on my 1970 Bug?
Posted: Tue Sep 14, 2010 02:13 PM
I am getting ready to take the body off the pan on my 1970 bug. I have stripped the interior, removed the fenders and bumpers. Removed the gas tank and engine. I have never taken the body off before and was wondering if there are any tricks or if anyone has any helpful hints.
Thanks
Ken
Post Post subject: Re: Any hints on removing the body on my 1970 Bug?
Posted: Tue Sep 14, 2010 02:50 PM
Well with what you have done your half way there. Just remove all the bolts from the body to pan under each side ( I think there is 11 on each side), there are 4 bolts inder the back seat area, 2 bolts in the front under the gas tank that fasten the body to the beam, remove the bolts to the steering coupler, and then there is one bolt on each side in the back that bolts the rear of the body to the upper chock towers. After that it should be ready to separate. Just lift it slowly to make sure you dont rip any wires or stuff like that. If you forget a bolt, you will know real quick.
Ken48442
Ken48442
Posted: Tue Sep 14, 2010 03:46 PM
I saw a couple other posts where it looks like people have put in some sort of cross brace that runs from side to side right behind the doors. Is this necessary? I have also seen other posts where the bracing wasn't used. Will my body flare out at the bottom if this isn't used?
Posted: Tue Sep 14, 2010 06:29 PM
If your heater channels are rotted away bracing is a good idea but if that is the case the body already may be twisted. Sound bodies do not need it.
Ken48442
Ken48442
Posted: Tue Sep 14, 2010 07:58 PM
Thanks. It looks like someone put new heater channels in recently so it sounds like I should be good.
Posted: Mon Sep 20, 2010 03:31 AM
If its a Michigan car....
Don't forget plenty of PB Blaster penetrating oil... Wink
Welcome to the site... Pictures... Question
Ken48442
Ken48442
Posted: Tue Sep 21, 2010 01:58 AM
I have large quantities of PB Blaster. My garage and part of my house smell like PB.
Body is off.
I will start a thread with pics. First thing I have to do is upload the pics to photobucket then I can post them here.
Posted: Wed Sep 22, 2010 12:42 AM
Excellent. Smile
25 Kreed 24350 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts New Members 1970 baja bug
New motor and transmission but won't move once in gear
3 Buggin420 2321 1970 baja bug
 Wed Dec 17, 2014 05:56 AM
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 4119 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Body Lifts 2 Darn_Near 2463 Re: Body Lifts
 Sun May 12, 2013 08:24 AM
No new posts Projects and Builds 1970 build 3 70bajathrash 3313 Re: 1970 build
 Sun Aug 05, 2012 01:26 AM
70bajathrash View latest post
