Visitors: 116
Total: 116
13: My Account
20: Pictures
51: Event Calendar
87: Event Calendar
89: Pictures
111: Pictures
114: Event Calendar
115: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Upholstery Foam???
Upholstery Foam???
Wldcat10
Wldcat10
Post Post subject: Upholstery Foam???
Posted: Fri Sep 10, 2010 06:58 PM
I stripped everything out of my baja 2 weeks ago and planned on putting bed liner on the floor. Now I cant make up my mind if I still want to put bed liner or just use the carpet kit that was already in it? Carpet is in pretty good shape and would just need a good washing. The floor pan is all ready to go. Should I put in the bed liner or just go with carpet that I already have? I was wondering where I could buy some upholstery foam for under the carpet, and what kind of adhesive I should use?
Posted: Fri Sep 10, 2010 07:50 PM
between deciding whether to do bedliner or carpet, the main question is is this a DD or an offroad only car?? If its an offroad only car the bedliner would be easier to clean, as the carpet tends to soak up mud and water if you have holes in the body or pan.
when you ask about upholstery foam are you talking about the glued together particle type foam?? or just regular foam??
you should be able to get either at a fabric store/warehouse or carpet store.
as for glue i would recommend 3M spray adhesive. it comes in a spray can and comes in different strengths. I've used just the regular duty stuff for the carpet in my car, and the heavy duty-super tacky stuff for the headliner in my car.
Wldcat10
Wldcat10
Post Post subject: Re: Upholstery Foam???
Posted: Fri Sep 10, 2010 09:01 PM
Well right now it is a offroad baja, but I will use it as my dd as soon as I take out the plates for it. Not too sure of the foam that I need? The foam that was under the carpet when I took it out was really old and nasty, it looked to me as if it had some sort of netting on it, sort of like a fishing line type net around the foam. There are no holes in my pan, some surface rust but no holes. I'm just trying to see what would work out the best for my budget. I dont have alot of money and would like to put either bed liner or the carpet kit I already have? But if the foam is going to cost as much as the bed liner I might as well put the bed liner? Only reason I'm undecided is because I read that alot of people have had their bedliner crack & chip off and also the bed liner loses it color and turns into an ashy grey?
Freeloader587
Freeloader587
Posted: Fri Sep 10, 2010 09:50 PM
the underfoam is cheap depends on what you want you dont really even need it just makes the carpet a bit softer and whatnot
kyle_pc_75
kyle_pc_75
Posted: Fri Sep 10, 2010 10:07 PM
I wouldn't put foam down without sealing the floor really well in some manner. I think it'd hold moisture and lead to possible rust issues.
Kyle
Wldcat10
Wldcat10
Posted: Fri Sep 10, 2010 10:12 PM
So if i decided to put the carpet back on, would you recommend me just putting the carpet itself without any foam under?
Freeloader587
Freeloader587
Posted: Fri Sep 10, 2010 10:29 PM
if you want dont really make a differnce if ur carpet was real nasty id pressure wash it and let it bake in the sun for a few days first
Posted: Fri Sep 10, 2010 10:35 PM
I would make it and the carpet on the floor removeable. When it is wet you don't want it holding the water against the floor for days.
Wldcat10
Wldcat10
Posted: Fri Sep 10, 2010 11:00 PM
I see what you guys are saying. Would it be a good idea spray paint the pan and then put on the carpet with adhesive? or should I just leave the pan the way it is and glue on the carpet?
Freeloader587
Freeloader587
Posted: Fri Sep 10, 2010 11:59 PM
there is now right or wrong way to do it its however you want to do it and what you want it to look like
VIN70
VIN70
Posted: Sat Sep 11, 2010 01:07 AM
i undercoated the pan, applied some sound deadening material, and then carpet. wouldnt recommend foam.
Posted: Sat Sep 11, 2010 08:37 AM
I have never put carpet in my Baja and it was my daily driver for close to 15 years. When it was time for a car show I would just repaint the floor black.
The only cloth in the car besides the seats is the head liner and that was new when I traded m '76 T/A for the car/Bug.
No new posts VW Volkswagen & Baja Bug General Discussion Headliner, interior upholstery
Wanted
1 desertbaja 1391 Re: Headliner, interio...
 Mon Sep 03, 2012 06:00 PM
