Latest: jor_dang420
Overall: 3597
Visitors: 130
Total: 130
13: My Account
14: Home
29: Event Calendar
44: Event Calendar
45: Home
82: Home
93: Home
104: Event Calendar
107: Event Calendar
108: Home
115: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- offroad lighting
offroad lighting
cperry2704
cperry2704
Post Post subject: offroad lighting
Posted: Mon Aug 02, 2010 10:54 PM
what is the best way to hook up a set of offroad lights? through the fuse box? or a hot wire with fuse directly to lights and ground them?
Post Post subject: Re: offroad lighting
Posted: Mon Aug 02, 2010 11:29 PM
I like to use a relay with a fuseable link feeding power to the relay and individual fuses for the lights.
kyle_pc_75
kyle_pc_75
Posted: Tue Aug 03, 2010 01:07 AM
X2
Kyle
cperry2704
cperry2704
Posted: Tue Aug 03, 2010 01:40 AM
lets say i run a power wire with inline fuse from the battery, will it start to drain the battery?
Posted: Tue Aug 03, 2010 10:39 AM
I use a set of BOSCH/KC 40A Black relays with a blade fuse. I have a terminal strip next to the battery and run the relay off from that strip. I also run them via ground trigger from a switch in the dash.
Most people run things of of hot wires +12volts. I do it a little backwards and run thelong wire grnd/switch wire from the switch in the dash.
I try to avoid long runs of Hot +12volt wires in my race cars/baja. If you have a wire brake down and short you have meltdowns etc. and maybe fire if you run ground trigger wires so you +12volt wires a short you keep the power were it needs to be and not run back and forth in your car.
Posted: Tue Aug 03, 2010 03:23 PM
Only if you leave the lights on. I will crimp 2 or 3 fuse link wires at one end and only use one in case of a short I can repair the short and use a good link. Fuses perform the same function.
cperry2704
cperry2704
Posted: Wed Aug 04, 2010 05:12 PM
im not so good with wiring, what exactly does the relay do?
so running the lights with car on and driving will not effect the charge of the battery?
Posted: Wed Aug 04, 2010 07:20 PM
Relays keep the load off the switch.
cperry2704
cperry2704
Posted: Thu Aug 05, 2010 12:12 AM
ok i get it, so im running 3 100w lights, how many relays will i need?
Posted: Thu Aug 05, 2010 03:18 AM
A single Bosh 40 amp relay shoud suffice.
2500Grunt
2500Grunt
Posted: Wed Aug 11, 2010 04:03 AM
A typical relay draws very little current and energizes an internal coil which can provide alot of output for things like lights, train horns, amp's etc. Use them so you don't overload wiring harnesses and fry em.
2332 turbo,IRS,bus tranny,4 seater
2500Grunt
2500Grunt
Posted: Wed Aug 11, 2010 04:16 AM
300w / 12 volts = at least 1- 25 Amp relay.
No new posts Events and Get Togethers World Wide FREE Offroad Show 3 wideopenmotorsports 3650 FREE Offroad Show
 Fri Apr 08, 2016 11:42 PM
No new posts Events and Get Togethers World Wide Lundes Vw Show AND Fodrlls Offroad Show 2 wideopenmotorsports 3349 Re: Lundes Vw Show AND...
 Wed Nov 06, 2013 10:59 PM
Hedrock View latest post
No new posts VW Volkswagen & Baja Bug General Discussion LIVE OFFROAD RACING TODAY Dec 10th 1 wideopenmotorsports 2612 Re: LIVE OFFROAD RACIN...
 Sat Dec 10, 2011 11:07 PM
No new posts Events and Get Togethers World Wide AzVC Presidents Day offroad camping trip.
20 perrib 16418 Re: AzVC Presidents Da...
 Wed Feb 23, 2011 02:38 AM
ikill6453 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion where to offroad in Tucson??? 0 JWHracing 1797 where to offroad in Tu...
 Fri Oct 22, 2010 06:07 AM
JWHracing View latest post
