Latest: xbluegto
Overall: 3573
Visitors: 189
Total: 189
04: Pictures
10: Home
22: My Account
121: Pictures
158: Baja Forums
164: Baja Forums
166: Baja Forums
171: Baja Forums
179: Baja Forums
180: Baja Forums
181: Baja Forums
183: Baja Forums
184: Baja Forums
185: Baja Forums
187: Baja Forums
189: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- I need HELP!
I need HELP!
seanoflinn1
seanoflinn1
Post Post subject: I need HELP!
Posted: Thu Jun 10, 2010 09:36 PM
Okay My bug is not starting i have no idea why i'm getting spark and my spark plugs are good im getting fuel to the carb and everything is wired right please help!
Post Post subject: Re: I need HELP!
Posted: Thu Jun 10, 2010 10:56 PM
You gotta give us more info.
Does it turn over?
Does it fire at all?
How do you know you have spark and fuel?
What happened to it before?
seanoflinn1
seanoflinn1
Posted: Thu Jun 10, 2010 11:05 PM
Well here is the deal IT does turn over and i know its getting spark because i checked Im guessing it has a problem with the carb or intake because its not firing.... I got the engine from a junk yard a guy just dropped it off because he got a bigger one it is a 1600cc motor it had a generator on it. the bug i have had a FI engine but it was effed so i grabbed this one the Carb motor started up and ran but would die because i had alternator wiring not generator soo the bat would die. I got a alt stand and put the alt back on and now it wont start up im confused. Maybe somthing with the ignition coil i dont know any ideas?
71_Bug
71_Bug
Posted: Sun Jun 13, 2010 05:37 PM
When I removed my Alt stand to put a gasket under it, the PO had neglected that part. I didnt think about disconnecting the battery and proceded to fry my Pertronix ignitor. Once I put a set of points back in and put the wires back on the coil correctly it started right up.
If you have the Ignitor instead of points I found a test for it somewhere online, also check the wires on your coil.
Bob
seanoflinn1
seanoflinn1
Posted: Sun Jun 13, 2010 06:36 PM
Got it started Kneedle valve in the carb was stuck!!! haha silly me!
