Latest: BlackIrish05009
Overall: 3574
Visitors: 142
Total: 142
13: Event Calendar
24: Home
38: My Account
39: Event Calendar
40: Event Calendar
48: Event Calendar
52: Event Calendar
61: Event Calendar
79: Event Calendar
82: Event Calendar
94: Home
97: Pictures
98: Event Calendar
111: My Account
118: Event Calendar
121: My Account
123: Event Calendar
129: Event Calendar
130: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- exhaust
exhaust
cperry2704
cperry2704
Post Post subject: exhaust
Posted: Mon Apr 19, 2010 07:25 PM
on a single port engine, there are tubes running from the intake to the exhaust, i think they are called preheater tubes? any idea what these are for? are they necessary? i am switching to a different exhaust system, and the new one doesnt have the flanges
Baja_Blue
Baja_Blue
Posted: Mon Apr 19, 2010 07:36 PM
They are for preheating the intake manifold. If you don't have them you will find your car running really bad in the lower RPM's when it's cold outside because the intake will basically freeze over and it won't be burning all of the gas.
I assume your switching to a Baja exhaust or something of the sort, and it's an easy fix with those.
Just pick up some of these...
www.chircoestore.com/c...ts_id=2934
drill small holes in them
then go to a local metal place and pick up some small tubing, cut your exhaust and weld those small tubes to it. Then weld the drilled block off plates to the tubes.
Then you can just use your old heat riser tubes with your new exhaust Cool
clear as mud? Laughing
Matthew 5:14-16
cperry2704
cperry2704
Posted: Mon Apr 19, 2010 07:41 PM
cool thx...yeah i have all the parts off my old exhaust
yeah i figured i would have to re-weld em on my new stuff, was just hoping for not
Baja_Blue
Baja_Blue
Posted: Mon Apr 19, 2010 08:10 PM
You can leave them off if you want. I don't have mine on and I have a single carb. But I live in So Cal so it's rarely cold here
I will do it one day...
Matthew 5:14-16
No new posts VW Volkswagen & Baja Bug General Discussion Exhaust 7 sandbuggy 3363 Re: Exhaust
 Sun Nov 17, 2013 01:15 AM
No new posts VW Volkswagen & Baja Bug General Discussion thunderbird H4207 - 4 Pipe Chrome exhaust
question for owners/ viewers of particular exhaust
13 beachmaster 7458 thunderbird H4207 - 4 ...
 Tue Nov 29, 2011 02:57 AM
beachmaster View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VW baja bug Exhaust options? 4 71VeeDub 7053 Re: VW baja bug Exhaus...
 Sun Nov 27, 2011 04:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Replacing exhaust
compatibility?
7 pschneider 4802 Replacing exhaust
 Mon May 17, 2010 12:37 AM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Difference between exhaust systems?
competition vs standard?
3 pschneider 2210 Difference between exh...
 Mon Apr 19, 2010 09:32 PM
Freeloader587 View latest post
