Latest: xbluegto
Overall: 3573
Visitors: 135
Total: 135
07: Event Calendar
24: Pictures
100: Event Calendar
117: Home
122: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Alt belt replacement
Kinsman
Kinsman
Post Post subject: Alt belt replacement
Posted: Tue Apr 13, 2010 05:05 PM
Hi all,
New guy here...new to bugs although that's what I learned to drive on....a few years ago. I bought a '72 baja that supposedly has had the engine and trans redone.
Because my wrench is bigger than my brain, I stripped the threads out of the nut on the rear of the alternator; a trip to the hardware store and I got a nut and washer that will work until I get another fancy chrome job.
What's the best way to get that damn belt back on the pulleys? Guess at the number of shims (I think I have three), tighten the nut, then put the belt over the alternator, and lever it onto the crankshaft pulley? Other way around? The belt seems awful damn tight.
Thanks in advance.
Post Post subject: Re: Alt belt replacement
Posted: Tue Apr 13, 2010 07:48 PM
The rear as in the 36mm nut that holds the cooling fan on or the front where the belt pulley is. If it is the front you'll need to roll the belt on. I would start with 8 shims between the plley halves and four on the out side.
Kinsman
Kinsman
Posted: Tue Apr 13, 2010 08:48 PM
It's where the pulley is.
Twelve shims total! Guess I better get some more...three or four came with the car.
edit: Put the belt on the crankshaft pulley first, thenthe alternator?
Chris
Long Riders Bar~B~Que
Florence, Montana
Posted: Wed Apr 14, 2010 04:30 AM
You add or substract shims to tighten the belt. Leave the front pulley half off put the belt on and then install the outer hal;f. I thought you did not want to take the nut off again.
Kinsman
Kinsman
Posted: Wed Apr 14, 2010 09:32 PM
OK, so as the pulley comes together it'll force the belt up to the edge. Makes sense.
Thanks.
Chris
Florence, Montana
No new posts VW Volkswagen & Baja Bug General Discussion fan belt replacement 0 azdesertrat87 1908 fan belt replacement
 Sat May 23, 2015 04:58 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fast Belt Change 6 Rickman 3012 Fast Belt Change
 Sat Jan 16, 2010 03:32 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Seat belt mount holes 6 locutisj 2341 Seat belt mount holes
 Wed Apr 01, 2009 03:18 AM
No new posts VW Volkswagen & Baja Bug General Discussion Cargo area and heater ?tinnels? replacement. 4 WaBaja 2018 Re: Cargo area and hea...
 Wed Apr 16, 2008 11:30 PM
WaBaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion more help for a new guy, how hard to find a replacement hood 5 mgh24 2177 Re: more help for a ne...
 Tue Oct 16, 2007 01:45 AM
mgh24 View latest post
