Latest: bawward
Overall: 3614
Visitors: 126
Total: 126
05: Event Calendar
14: Home
15: Home
64: Event Calendar
65: Event Calendar
73: Event Calendar
76: Event Calendar
77: Event Calendar
79: Event Calendar
81: Event Calendar
87: Home
90: Event Calendar
117: Pictures
121: Event Calendar
126: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Relays
Relays
72BajaBen
72BajaBen
Post Post subject: Relays
Posted: Tue Oct 10, 2006 06:31 PM
So i was wondering, the more electrical stuff you add the worse your battery is going to fair. so is there any way to help out the electrical system. will adding relays help with the load? What exactly does a relay do? Do they make cap's to help with the load of lights and such, like they do for sound systems? Thanks
beetfeet
beetfeet
Post Post subject: Re: Relays
Posted: Tue Oct 10, 2006 06:50 PM
A relay is basically an electrically controlled switch, so it won't help much. The best thing to do is upgrade the alternator and battery.
A battery with more CCA(cold cranking amps) can supply more power. A 950 CCA battery has more power than say a 550 CCA battery.
Alternators are rated in watts(power). A 230W alt from a new Dodge diesel is going to put out more power than say a 120W alt from a Toyota Camry.
Caps (capacitors) on the other hand are energy storage devices. They can't supply more energy than they are charged with. They also discharge very quickly. They work for stereo's because they can boost power for a short time and they recharge almost as fast as they disharge. We are talking in the micro second timeframes. Perfect for adding some bass to your favorite Trance songs!
I like the way you think though, you have any other ideas??
My mother never saw the irony in calling me a son-of-a-bitch
saltyslug
saltyslug
Posted: Tue Oct 10, 2006 07:00 PM
relays are just bigger amp switches to make so the little switches on your dash(newer cars) don't have to run so much amperage through them. little switches will literally melt or burn up if you try and push to many amps through them.
It is going to depend on the charging system you have on your engine right now. do your have a alternator or a generator?
if you have a generator you need to get a alternator first then that would be a good start. beef up your charging wires also. cars 40+ years old most likely need a freshning on the alternator wire and new ground leads as well.
also a new battery would probably help!
anytime you can put insulated connectors on all the wires you come across that arent insulated do it.
the stock bug generator barely puts out 35 amps worth of powah, a motorolla alternator can put out close to 60 amps and some can put out close to 80. 60-80 should be enough for a good system and some lights.
I seen it too many times where a person would come in the shop with a 800watt rockford fosgate or some other alt killing machine and the amperage of the amp would suck more than a bug generator could put out, same with hondas and other small cars.
just add up the amperage of your devices and keep it under the alts output.
Posted: Tue Oct 10, 2006 08:06 PM
all in all, go with a NEW bosch alternator at the highest output you can afford.
stay away from relays unless absolutely necassary.
they are on the sand limos and they bite azs. if they get wet, theyre history. they take up precious room too.
72BajaBen
72BajaBen
Posted: Wed Oct 11, 2006 12:38 AM
Thanks for the input. Im not planning on putting a large system in my baja, and i have a Bosch Alt in it already. i dont know what the amp output is though. it was already on there. The battery is pretty new, but i will look in to getting one with more CCA's. If you guys have any other ideas let me know.
Thanks
Posted: Wed Oct 11, 2006 01:33 AM
another note, pick up the largest battery you can afford. i run an 800 plus cold crankin amp battery. that way there is plenty of crank over even when its weak. Very Happy
Say10
Say10
Posted: Wed Oct 11, 2006 03:06 AM
If you have cash invest in a Optima red top battery as well as the new alt.If you go to an actual battery store like Batteries Plus (or what ever they have over in Cali) they tend to be cheaper than anywhere else. They have a 3 year warranty and are dry cell. My boss has one in his old Wagoneer and swears by em now.
Posted: Wed Oct 11, 2006 04:21 AM
optimas are nice, but they do die sooner than a standard acid battery.
Staff Officers
Posted: Wed Oct 11, 2006 05:16 AM
Amps and Stereo. I had too small an alt on my Duster and to big a stereo, So when I was out cruzing with it up and loud I would kill my battery even when the car was running.
Posted: Wed Oct 11, 2006 05:18 AM
with huge stereos, you need to run 2 batteries Very Happy
other wise you kill the single one.
Posted: Wed Oct 11, 2006 05:22 AM
I have a yellow top optima that sat at the Pep boys I worked at for 2 years then at my house for a year, I have since used it in several different cars and have yet to kill it.
Posted: Wed Oct 11, 2006 05:25 AM
youre the exception.
from experience. NEW batteries will die in a day here in AZ. some last 7 yrs with no probs. its a choice he must make.
GRASSHOPPER........are you ready!?!?
madman74
madman74
Posted: Wed Oct 11, 2006 06:15 AM
Hi all sorry to hijack but the O of my baja ran relays for everything. I want to clean up the wiring some and was thinking of removing some of them. What do you think is important to have a relay on? The switches seem to be pretty heavy duty. Do you think it would be ok to run the haedlights through a toggle switch, and the brights and KCs throught other switches and remove the relays? I dont think the headlights draw all that many amps.
Thanks
Shawn
72BajaBen
72BajaBen
Posted: Wed Oct 11, 2006 08:13 AM
I have all of my stuff going through toggle switches, i dont have any relays. I havent had any problems with any of my stuff. my headlights offroad lights, windshield wipers and horn ar all run through toggle switches.
Posted: Wed Oct 11, 2006 08:34 AM
Thanks
Shawn
all of my lights are toggles of some sort. some are lighted so you know they are on (floods, etc). the only relay i had was for the stinkin cheap asz horn i put in and ripped out.
