Visitors: 111
Total: 111
02: Event Calendar
68: Event Calendar
95: Event Calendar
102: Event Calendar
110: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 4 to 5 lug pattern
4 to 5 lug pattern
NAXZ
NAXZ
Post Post subject: 4 to 5 lug pattern
Posted: Fri Mar 05, 2010 01:48 AM
this might sound a little dumb since i dont know the proper names for the parts or stuff, but, i believe that vw buses have a 5 lug pattern (correct me if im wrong)
can i fit the *drum*(i really dont know that these are called :$....anyways they are the piece that the wheel attaches too) can i fit from a bus into a bug? so it changes the 4 lug to a 5 lug pattern?
if i cant, which ones do i have to get that fit? and i have seen some but they are a tad out of my price reach :/.....im trying to find one that i can take off a old car, (in some junkyard)
ps: i see some 5 spoke wheels in chirco.com, which are probably the ones im going to get, but i didnt find the size of the lug pattern.....so, the *drum* should have the pattern to match those wheels...
greentowtruck
greentowtruck
Posted: Fri Mar 05, 2010 04:24 AM
The 4 lug bug is 4 on 130mm The wide 5 lug pattern is 5 on 205mm and 5 lug vanagon is 5 on 112. I dont believe you can fit a bus drum on a bug because the bus has a larger spline on the rear and different size bearings up front.
As far as converting 4 lug to 5 lug the you can use a set of wheel adapters but I personally dont like them, or expensive disc brake conversion. There may be other ways but I dont know what they are.
NAXZ
NAXZ
Posted: Fri Mar 05, 2010 04:27 AM
yeah, i dont like the idea of having a metal plate to hold my wheel, i just dont trust those :/
but i really want the 5 lug pattern, i know some bugs have them, though i dont know which year....you think i could find them somewhere?
greentowtruck
greentowtruck
Posted: Fri Mar 05, 2010 04:35 AM
bugs up to 66 i think were 5 lug I am not positive on the exact year but they were link pin front and swing axle mostly but there night have been a slight crossover when they switched from link pin to ball joint or when they switched from swing axle to cv rear.
NAXZ
NAXZ
Post Post subject: Re: 4 to 5 lug pattern
Posted: Fri Mar 05, 2010 04:38 AM
and i suppose i can fit '66 drums on a '70-present bug?
greentowtruck
greentowtruck
Posted: Fri Mar 05, 2010 04:51 AM
I cant answer that question for you but somebody else here should be able to. Sorry it has been years since I have worked on bugs and I have forgotten alot of the specs.
NAXZ
NAXZ
Posted: Fri Mar 05, 2010 04:52 AM
no problem, you allready helped Very Happy
Posted: Fri Mar 05, 2010 06:34 PM
If you have a 68 & up bug (not a super beetle) you can use the front drums from a 66 or 67 bug and they will bolt right on. On the rear you have 2 options, you can find drums from a 73 or 74 thing and they are a direct bolt on, they are a little spendy though. You can use the 66 & earlier bug drum, but you will have to use a spacer between the nut and drum becasue the snout is shorter.
Posted: Sat Mar 06, 2010 05:12 PM
The steal 4 to have plates are stonger than the rim and most front end parts. I would not worry about them.
Just make sure you o not buy the cheap cast ones
NAXZ
NAXZ
Posted: Sat Mar 06, 2010 05:16 PM
guess this one will work?
www.chircoestore.com/c...ts_id=2407
Posted: Mon Mar 08, 2010 05:27 AM
Thats the ones Eric(AzBaja) is talking about. I was with him when he bent a spindle, and the adapter didnt give at all. He has been running those adapters for at least 15 years, probably longer.
Posted: Tue Mar 09, 2010 03:31 AM
X2
Just make sure and use nine 14 mm studs and T-2 lug nuts.
Posted: Wed Mar 10, 2010 01:12 PM
Man I should not type so early/late in the morning...Makes us night workes look like we can no type a single line...
Yes the 4 to 5 adapters are stronger than your rims and other front end parts, Trust me on that.
Posted: Wed Mar 10, 2010 02:30 PM
[quote="AzBaja"]Man I should not type so early/late in the morning...Makes us night workes look like we can no type a single line...
I thought that was written with the secret AZ Baja code. Smile
Baja_Blue
Baja_Blue
Posted: Thu Mar 18, 2010 11:29 PM
What do you guys think of these...?
www.chircoestore.com/c...u4b2vadel6
It would be so much more convinient to have the same bolt pattern as my brother's ranger and there are alot more possibilities for wheels I can buy
Matthew 5:14-16
