Latest: Curtis
Overall: 3613
Visitors: 145
Total: 145
03: Home
05: Event Calendar
07: Event Calendar
12: Event Calendar
19: Event Calendar
27: Event Calendar
31: Event Calendar
50: Event Calendar
56: Home
80: Event Calendar
87: Home
96: Home
98: Garage
103: Home
111: Event Calendar
118: Event Calendar
119: Event Calendar
125: Home
126: Home
127: Home
133: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Leaking centerlines..
Brettucks
Brettucks
Post Post subject: Leaking centerlines..
Posted: Sat Jan 30, 2010 09:36 PM
Rear centerline rims (2 piece) are leaking badly between pieces.. one has to be filled daily.. tires are new and couldnt find any major leaks around bead but big bubbles between plates... and remedy for this or reccommendations for a differrent basic rim?
rims are 15 x 9 (ish) and wide 5 pattern...
-Brett
Posted: Sat Jan 30, 2010 09:51 PM
If you can break the bead, I've heard of people siliconing the split between the two pieces. Might be worth having them dismounted for a day or two, even if it means two trips to Discount...
If you apply the sealant sparingly, it shouldn't even affect the balance. But, since you're dismounting them anyway, having them balanced would probably be advisable.
I don't think "Slime" or any of that Fix-a-Flat crap will work, as centrifugal force keeps it smeared all over the inside of the tires, not around the rim.
Brettucks
Brettucks
Posted: Sat Jan 30, 2010 11:52 PM
Well it seems someone tried that so I need some new wheels--
-Brett
DutchBug
DutchBug
Posted: Sun Jan 31, 2010 12:34 AM
I used a fix a flat kinda stuff and it worked fine for me. I kept getting flats on the low profile tires on my lowered 1303. I sprayed the stuff in and it worked well. You have to drive slow for about 15 km it says on the spraycan and I think that is important. It doesn't cost much so you could try.
Post Post subject: Re: Leaking centerlines..
Posted: Sun Jan 31, 2010 09:00 AM
Brettucks wrote:
Rear centerline rims (2 piece) are leaking badly between pieces.. one has to be filled daily.. tires are new and couldnt find any major leaks around bead but big bubbles between plates... and remedy for this or reccommendations for a differrent basic rim? rims are 15 x 9 (ish) and wide 5 pattern... -Brett
Brett, centerline wheels are two piece, they have silicone sealent from factory and after off road use they can start to leak. You will need to cut out the old silicone clean thouroughly with brake cleaner and re silicone. let it dry for atleast 24hrs before putting tires back on. I have had to do this on other wheels for years. any problems just call.
Staff Officers
Posted: Sun Jan 31, 2010 05:35 PM
Centerlines a re a rebuildable wheel. It splits in the middle. We used to use bathtub silcon to seal them on the drag car. Did it in 2 pass per rim. 1 small bead about 1/8" wide to fill deep into the grove. Then after that drys for 12 to 24 hours a 2nd fat bead was smoothed over the 1st one.
Posted: Mon Feb 01, 2010 07:25 PM
If the silicone doesn't work, run a tube. Ne reason to ditch the centerlines.
kyle_pc_75
kyle_pc_75
Posted: Tue Feb 02, 2010 02:02 AM
Here's a question. What's the benefit of a two piece rim?
Kyle
Staff Officers
Posted: Tue Feb 02, 2010 07:38 AM
Centerlines are made from 2 flat spun aluminum disc that are di stamped into the shape of half a rim. Both half are riveted together to get a whole rim.
Real stong and light. If you bend one it can be taken apart and restamped into shape.
Kyle
Posted: Wed Feb 03, 2010 01:32 AM
Kyle
Also cheaper to manufacture with numerous combinations of backspacing/wheel width. Think mix and match.
No new posts VW Volkswagen & Baja Bug General Discussion Engine leaking gas while parked... 8 pschneider 8010 Re: Engine leaking gas...
 Sat May 01, 2010 12:10 AM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion stupid leaking gas tank gaskets... 3 Brettucks 3844 stupid leaking gas tan...
 Fri Aug 07, 2009 10:38 PM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion leaking axle 11 cperry2704 4375 Re: leaking axle
 Wed Dec 05, 2007 09:42 PM
fatalifeaten View latest post
