AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Another new guy with more questions
Users browsing this topic:
None
Author |
Message |
NAXZ
+1
Post subject: Another new guy with more questions
Posted: Sun Jan 31, 2010 05:40 AM
i have one more question......
if i follow the guide from this link
<http://www.bluegrassghostinvestigations.com/baja.htm>
, will the front tires rub someplace if i turn too much? (without stoppers)
im really new to all of this, thats why im investigation a LOT (im the kind of guy that has to have everything PERFECT) lol
also, is there a way to make the back tires stick out a bit more?
note that im in a tight budget here, but i know how to weld a bit, and have access to quit a lot of scrap metal
+51
+16
Posted: Sun Jan 31, 2010 04:26 PM
Also do not use stock VW rims. get a set of the white wagon wheel type rims. You gain from 1" to 1.5" of width per side over the stock VW rims.
NAXZ
+1
Posted: Sun Jan 31, 2010 07:59 PM
i know this might sound a bit dumb, but what are "white wagon wheel type rims"? :$
+15
Posted: Sun Jan 31, 2010 10:54 PM
_________________ ... HAMMER IT TO FIT,,PAINT IT TO MATCH !!! A people that values its privileges above its principles ,Will soon lose both!
vindeta
+2
Posted: Wed Feb 03, 2010 11:46 PM
nice clean lookin baja james.
perrib....can you like give me those tires? those are freakin awesome..
i need some.
heres my rims...you can see how much farther they stick out than stock rims...
if you compare with perribs rims...
btw these type of rims are officially called "spoke" rims so if you search those you find what you want.
there like $50 new so there nice and cheap.
the stock ones cover up the whole brake drum. mine only cover it about 1/5 inch...you can see almost the whole drum from the front..
_________________ 75 baja in pieces in the garage
+16
+15
Posted: Thu Feb 04, 2010 02:20 AM
thanks,,,just showing,,white spokes,,i have disk in the front,,,,but you can get them in just about any offset you would like!
vindeta
+2
vindeta
+2
Post subject: Re: Another new guy with more questions
Posted: Sun Feb 07, 2010 02:56 AM
NAXZ wrote: |
note that im in a tight budget here, but i know how to weld a bit, and have access to quit a lot of scrap metal |
btw on yur question about the tires rubbing. there are two set screws that limit how far the tires can turn. so you can just crank those in a little bit and it will keep your tires from rubbing.
ahha i found the picture i was looking for.
as you can see on the left side of the beam next to the left shock tower. there is that metal tab with a bolt sticking out of it. there is another bolt below it and the arm on the steering box hits those bolts at the limits of it travel. btw my steering box is out right now but it goes just to the right of that tab.
hope that helps....
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
