Latest: Curtis
Overall: 3613
Visitors: 183
Total: 183
11: Event Calendar
13: Event Calendar
18: Event Calendar
22: Event Calendar
24: Event Calendar
42: Event Calendar
48: Event Calendar
58: Home
84: Pictures
91: Home
114: Home
124: Event Calendar
135: Event Calendar
138: Event Calendar
142: Event Calendar
145: Event Calendar
154: Baja Forums
162: Baja Forums
172: Baja Forums
176: Baja Forums
177: Baja Forums
178: Baja Forums
179: Event Calendar
180: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- pinto adapter
pinto adapter
saltyslug
saltyslug
Post Post subject: pinto adapter
Posted: Tue Oct 03, 2006 10:59 PM
does the pinto adapter work with the 2.3 turbo from the turbo coupe and mustang?
Staff Officers
Post Post subject: Re: pinto adapter
Posted: Tue Oct 03, 2006 11:18 PM
yes, all Ford 2.3OHC engines are the same bell patern as far as I know. You might need to move some pips but it should bolt up.
madman74
madman74
Posted: Wed Oct 04, 2006 12:09 AM
Ok finally something I can answer. Yes all of the old iron sohc 2.0/2.3/2.5 engines use the same bellhousing bolt pattern. The older 2.0 sohc use the same bolt pattern also but use a different size locating dowel (they make a steped dowel so you can switch them around though. The later aluminum 2.0 and 2.3 dohc engine use a different belhousing. If you need any info on building up your 2.3t let me know I have built many. My last 2.3t was in an 83 turbocoupe and had stock 100,000 bottom end and few aftermarket parts and in a 3470lb car ran 13.2 at 103mph on street tires and a slipping clutch also had stock t-3 turbo. Check out turboford.org. I am sctur601 overthere.
Posted: Wed Oct 04, 2006 12:37 AM
what kinda hp and torque do these engines make ? non turbo
saltyslug
saltyslug
Posted: Wed Oct 04, 2006 01:18 AM
^^^^^ more than a bug and thats all you need to know, LOL
saltyslug
saltyslug
Posted: Wed Oct 04, 2006 05:27 PM
I might have scored a adapter for $150, hopefully.
madman74
madman74
Posted: Wed Oct 04, 2006 11:58 PM
If you get it mke sure it comes with the vw/2.3 flywheel. its expensive to buy one seperate.
saltyslug
saltyslug
Posted: Thu Oct 05, 2006 04:39 AM
it comes with the adapter, flywheel, and the clutch and pressure plate. he said he also has a mallory distributer for a pinto engine and a complete motor but it is apart.
anyone interested in the distributer?
saltyslug
saltyslug
Posted: Thu Oct 05, 2006 11:08 PM
I got the adapter, it looks good. it is a Pinto Beans adapter. it has a 6 puck and hd pressure plate. I cant find a poundage on the kep pressure plate though??
it was only $150 for it all, but the $206 speeding ticket bumped the price up. oh well looks like I gotta sell some turbos to make up the difference.
the guy works at a machine shop and has a iron head(no cracks) and a mallory dizzy with coil. $100 for the extra parts. if anyone wants them pm me or comment here.
Staff Officers
Posted: Fri Oct 06, 2006 12:04 AM
use a 2200lb presure plate at the most and get a normal VW spring type disc.
saltyslug
saltyslug
Posted: Tue Oct 10, 2006 11:24 PM
well I won another adapter on evil bay. I got this one for $75 shipped to my door. It is for a pinto engine it looks like also. The guy did not know what type of engine it fit. SCORE
I will post pics of both setups when I get the second.
saltyslug
saltyslug
Posted: Mon Oct 16, 2006 06:18 AM
here are the two adapters side by side. it is definatly a pinto adapter. it is a homemade unit that has been turned down on a lathe. this is one heavy mofo. it was $75 to my door. I gotta see if kennedy sells the bolts for the adaper unless you guys know a place to get the long starter bolt. now I gotta start looking for engines. I wanna run EFI later style engines if po$$ible. let me know what ya think.
cactusdog
cactusdog
Posted: Tue Oct 24, 2006 01:15 AM
Forget the ford,go with a subaru,I have a 2.0,potr injected,turbo in my 65,can't beat it.
Posted: Tue Oct 24, 2006 06:31 AM
you got pics cactus, of the install ?
cactusdog
cactusdog
Posted: Tue Oct 24, 2006 07:22 AM
cactusdog
cactusdog
Posted: Tue Oct 24, 2006 07:27 AM
YES and if I could figure out how to put it in this box I would. lol I'll try to put it in the gallarie.
Posted: Tue Oct 24, 2006 07:30 AM
Where do you have it uploaded to?
cactusdog
cactusdog
Posted: Tue Oct 24, 2006 07:47 AM
saltyslug
saltyslug
Posted: Wed Oct 25, 2006 10:00 PM
hey cactusdog I do have you beat. I have a turbochraged nissan 300zx engine in the back of mine. should be good into the 500hp range on stock internals. don't knock the ford lump either, Crash will be putting down 350hp on his setup. for the price of a suby I could have bought 4-5 of my engines. plus when you say you have a turbo v6 most people don't want to race anymore. even STI subies Wink
saltyslug
saltyslug
Posted: Wed Oct 25, 2006 10:09 PM
heres a more recent pic, those are the 16in wide paddles I got. I just got some tires from him also. sandlake here I come.
cactusdog
cactusdog
Posted: Thu Oct 26, 2006 03:09 AM
true to a point on the 300zx engine,but how good does that thing fit. 2.5 sbies are putting out beyond 600hp reliably,and it's a boxer that fits right in. My 2.0 was $800.00 w/turbo,and header,another $800 for a programable ecu, and I have about 350hp at about 150lb less. A bug out at the duns had a northstar, what a pice, so much wieght behind the back wheels,he couldn't turn without the brakes. Some times a little less is more.
saltyslug
saltyslug
Posted: Fri Oct 27, 2006 05:19 PM
my motor actually paid for its self when I parted the z car out. I bought the car for $200 and parted it out for aroud $250 and got $75 for the scrap weight. totally stock ecu is good til about 400hp and 500 can be had for about $500. you cant be pushing no 350hp from the ej20 unless you went with a bigger turbo and other goodies(like a sti turbo upgrades $500 or nox.). the ej25t is a $3000+ engine though and that more than what I have in the entire car.
the nissan lump has no low oil pan issues that the ej suby engine have either. the pan is actually as high as the tranny so the skid plate runs to the rear just like it would with a bug engine. I have NO weight issues at all, I actually drive it pretty fast on the highway and on the loggin roads doing 50+mph and it seems great, plus the shear torque of a v6 makes a huge difference hill climbing.
don't get me wrong the suby is a nice piece and I will probably be doind a couple of them cause I have some bus buddies that want that engine in the back of thier campers but I am gonna wait to see how they do for the extra weight of a bus.
saltyslug
saltyslug
Posted: Fri Oct 27, 2006 05:38 PM
that super sitting next to the baja has my old baja setup. 12a rotary engine I had turboed before but just got tired of the cold start issues so now she is NA again. I thought a super with a 8000rpm redline would be fun on the streets and road coarse at PIR.
cactusdog send me your pics and I will start a new post and post em for ya. I wanna see your setup. good luck with it and if you find and adapters for the scooby lumps let me know. also welcome to the site.
cactusdog
cactusdog
Posted: Sat Oct 28, 2006 04:42 AM
[img]http[align=justify][marq=up]://www.photodump.org/stored8/PICT1375.JPG[/img]
No new posts VW Volkswagen & Baja Bug General Discussion wtb subaru engine adapter. 2 baja66 3718 wtb subaru engine adap...
 Sun Jan 01, 2012 08:56 AM
baja66 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 2.8 gm adapter??? 5 baja66 2303 2.8 gm adapter???
 Tue Nov 08, 2011 02:31 AM
No new posts VW Volkswagen & Baja Bug General Discussion trans adapter for 1.6 hyundai motor 1 trumpit 2133 Re: trans adapter for ...
 Wed Dec 17, 2008 06:03 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Pinto 2.3 adapters
16 joxracing 11204 Re: Pinto 2.3 adapters
 Sat Jan 12, 2008 10:37 AM
Crash View latest post
No new posts VW Volkswagen & Baja Bug General Discussion water cooled adapter plate 2 soopercoop 2224 Re: water cooled adapt...
 Sun May 06, 2007 05:50 PM
coreyvdg View latest post
