Visitors: 110
Total: 110
23: Event Calendar
53: Pictures
59: Event Calendar
60: My Account
78: My Account
79: Event Calendar
94: Event Calendar
96: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- pinto adapter
pinto adapter
saltyslug
saltyslug
Post Post subject: pinto adapter
Posted: Tue Oct 03, 2006 10:59 PM
does the pinto adapter work with the 2.3 turbo from the turbo coupe and mustang?
Post Post subject: Re: pinto adapter
Posted: Tue Oct 03, 2006 11:18 PM
yes, all Ford 2.3OHC engines are the same bell patern as far as I know. You might need to move some pips but it should bolt up.
madman74
madman74
Posted: Wed Oct 04, 2006 12:09 AM
Ok finally something I can answer. Yes all of the old iron sohc 2.0/2.3/2.5 engines use the same bellhousing bolt pattern. The older 2.0 sohc use the same bolt pattern also but use a different size locating dowel (they make a steped dowel so you can switch them around though. The later aluminum 2.0 and 2.3 dohc engine use a different belhousing. If you need any info on building up your 2.3t let me know I have built many. My last 2.3t was in an 83 turbocoupe and had stock 100,000 bottom end and few aftermarket parts and in a 3470lb car ran 13.2 at 103mph on street tires and a slipping clutch also had stock t-3 turbo. Check out turboford.org. I am sctur601 overthere.
Posted: Wed Oct 04, 2006 12:37 AM
what kinda hp and torque do these engines make ? non turbo
saltyslug
saltyslug
Posted: Wed Oct 04, 2006 01:18 AM
^^^^^ more than a bug and thats all you need to know, LOL
saltyslug
saltyslug
Posted: Wed Oct 04, 2006 05:27 PM
I might have scored a adapter for $150, hopefully.
madman74
madman74
Posted: Wed Oct 04, 2006 11:58 PM
If you get it mke sure it comes with the vw/2.3 flywheel. its expensive to buy one seperate.
saltyslug
saltyslug
Posted: Thu Oct 05, 2006 04:39 AM
it comes with the adapter, flywheel, and the clutch and pressure plate. he said he also has a mallory distributer for a pinto engine and a complete motor but it is apart.
anyone interested in the distributer?
saltyslug
saltyslug
Posted: Thu Oct 05, 2006 11:08 PM
I got the adapter, it looks good. it is a Pinto Beans adapter. it has a 6 puck and hd pressure plate. I cant find a poundage on the kep pressure plate though??
it was only $150 for it all, but the $206 speeding ticket bumped the price up. oh well looks like I gotta sell some turbos to make up the difference.
the guy works at a machine shop and has a iron head(no cracks) and a mallory dizzy with coil. $100 for the extra parts. if anyone wants them pm me or comment here.
Posted: Fri Oct 06, 2006 12:04 AM
use a 2200lb presure plate at the most and get a normal VW spring type disc.
saltyslug
saltyslug
Posted: Tue Oct 10, 2006 11:24 PM
well I won another adapter on evil bay. I got this one for $75 shipped to my door. It is for a pinto engine it looks like also. The guy did not know what type of engine it fit. SCORE
I will post pics of both setups when I get the second.
saltyslug
saltyslug
Posted: Mon Oct 16, 2006 06:18 AM
here are the two adapters side by side. it is definatly a pinto adapter. it is a homemade unit that has been turned down on a lathe. this is one heavy mofo. it was $75 to my door. I gotta see if kennedy sells the bolts for the adaper unless you guys know a place to get the long starter bolt. now I gotta start looking for engines. I wanna run EFI later style engines if po$$ible. let me know what ya think.
cactusdog
cactusdog
Posted: Tue Oct 24, 2006 01:15 AM
Forget the ford,go with a subaru,I have a 2.0,potr injected,turbo in my 65,can't beat it.
Posted: Tue Oct 24, 2006 06:31 AM
you got pics cactus, of the install ?
cactusdog
cactusdog
Posted: Tue Oct 24, 2006 07:22 AM
No new posts VW Volkswagen & Baja Bug General Discussion wtb subaru engine adapter. 2 baja66 3143 wtb subaru engine adap...
 Sun Jan 01, 2012 07:56 AM
baja66 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 2.8 gm adapter??? 5 baja66 1899 2.8 gm adapter???
 Tue Nov 08, 2011 01:31 AM
No new posts VW Volkswagen & Baja Bug General Discussion trans adapter for 1.6 hyundai motor 1 trumpit 1902 Re: trans adapter for ...
 Wed Dec 17, 2008 05:03 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Pinto 2.3 adapters
16 joxracing 9468 Re: Pinto 2.3 adapters
 Sat Jan 12, 2008 09:37 AM
Crash View latest post
No new posts VW Volkswagen & Baja Bug General Discussion water cooled adapter plate 2 soopercoop 1808 Re: water cooled adapt...
 Sun May 06, 2007 05:50 PM
coreyvdg View latest post
