Latest: ecthemc
Overall: 3567
Visitors: 157
Total: 157
24: Pictures
60: Event Calendar
78: Event Calendar
134: Event Calendar
151: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What year really is my baja?
Blake22211
Blake22211
Post Post subject: What year really is my baja?
Posted: Thu Dec 03, 2009 11:47 PM
Okay, so the pink says it is a 68...
but here's what makes me think it is a 67 or earlier...
1. tail lights are 67 and earlier
2. wiring diagram matches a 67 not a 68
3. it had stock LOWback seats
4. the turn signal lamps I believe are 67 and earlier
5. not sure if a swing axle/ball joint combo was made in 68? didn't 68 switch to IRS?
Straights are for fast cars...Turns are for fast drivers...
My Garage Link!
Posted: Fri Dec 04, 2009 03:27 AM
First off...The car is about 40 years old. Few of them are even remotely close to original. VW Bugs haven't even been imported into the US in 30 years. A lot of the members on here weren't even born when the last Bug was sold new in the US. Lots of things are likely to have been changed in that time. It may have a 67 body on a 68 pan for instance...
- see above, and it's a Baja with different fenders
- see above
- see above
- see above
- In 68s Only AutoStick trans cars got IRS. All other 68 Bugs were still swing axle. All 69s sold in the US were IRS. Original 68 axles were long axle-long spline, and a Z-bar was installed across above the trans connecting the suspension to reduce "Jacking Effect". 67s came with 5 lug wheels while 68s are 4 lug.
To verify the year of your pan, check the VIN on the pink, in the pan on top of the tunnel under the rear seat bottom and on the top left of the dash. If it is a 67, it will start with "117", a 68 will start with "118". If the body has been swapped, the numbers on the dash and under the back seat will probably not match, or the dash tag may have been removed
Blake22211
Blake22211
Posted: Fri Dec 04, 2009 07:16 AM
haha alright, I'm not too worried about it. btw, the VIN on the dash was popped out. probably just a body swap. the VIN starts with a 118. wheels are 5 lug though haha
My Garage Link!
4 Admin_AzBaja 5040 Baja Bugs on Wiki need...
1567 mufasavnvmc 837050 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 205448 Re: Baja sightings
Off-road event
1 wideopenmotorsports 100 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts Events and Get Togethers World Wide The AVC New Year’s campout
99 Dalton 25438 The AVC New Year’s c...
 Fri Dec 29, 2017 07:06 PM
