Visitors: 120
Total: 120
08: Event Calendar
32: Event Calendar
86: Event Calendar
96: Event Calendar
117: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Non Fuel injection
Non Fuel injection
ajeden
ajeden
Post Post subject: Non Fuel injection
Posted: Mon Oct 02, 2006 06:58 PM
Hi guys
I have other questions for you.
My '96 bug should be F.I but it doesn't have it. I have a 34 PICT-3 carb. At the moment the acceleration is not great and a little lumpy. Is this carb ok running on a F.I model. Also I have 2 timing marks on the pully? I have tried to set the timing but if I aline the right hand of the 2, it doesn't sound good so at the moment it is just to the left of the seam on the block.
I have also just had some major work done (motor out, pulled apart and new push rods fitted) The mechanic here has told me that the pistons are different on F.I models, I am now totally confused. Should I invest in F.I or can I change the carb for a more friendly one for F.I
Hope you can help me.
Regards
Andrew
Post Post subject: Re: Non Fuel injection
Posted: Tue Oct 03, 2006 04:40 AM
I duno. Confused
ajeden
ajeden
Posted: Tue Oct 03, 2006 05:31 AM
Mykul wrote:
I duno. Confused
Thanks for the reply. Any info would be nice.
saltyslug
saltyslug
Posted: Tue Oct 03, 2006 10:32 PM
the best thing you can possibly do is get a new carb. they are only $120 at most, and the difference is night and day. you also need the book called "how to keep your volkswagen alive" the book is a MUST HAVE for begginers. read that book 10 times(I probably read it 80 or more times).
the motor did not need to be pulled to do push rods. you either need to start working on it yourself or just buy a newer car, cause a bug and a mechanic= big bucks.
I don't think the pistons are different, it wouldn't make much sense would it? the heads may be different for the injectors but that would probably be it. the cases are a little different but it shouldn't affect it much. just get the new carb and the book.
you need to know what distributer and pulley you have to time that thing. since it was FI before you never know what they changed when they did the carby swap.
google search "vw bug distributer differences" or something like that. searching on the WWW and the book makes it alot easier than guessin.
why post if you dont know?? Question Idea Evil or Very Mad
ajeden
ajeden
Posted: Wed Oct 04, 2006 04:46 AM
Thanks for the advice. I'll try and get the book and more info on the bug. As you can see I live in Mexico, so everything is that much harder.
Regards
saltyslug
saltyslug
Posted: Wed Oct 04, 2006 05:11 AM
should be cheaper for a carb there??? Cool
ajeden
ajeden
Posted: Thu Oct 05, 2006 07:18 PM
Thanks
saltyslug
saltyslug
Posted: Thu Oct 05, 2006 11:04 PM
let us know how she does, and some pics too. good luck
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1716 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3416 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 1765 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fuel Filler Ideas? 4 catchbats 5784 Fuel Filler Ideas?
 Sat Jul 11, 2009 09:04 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion main fuel line leak... 6 Kev_n_AZ 2661 Re: main fuel line lea...
 Fri Dec 05, 2008 04:25 PM
Kev_n_AZ View latest post
