Visitors: 112
Total: 112
13: Event Calendar
51: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Fuel pump failure
Fuel pump failure
chickenpants
chickenpants
Post Post subject: Fuel pump failure
Posted: Sun Nov 01, 2009 11:08 PM
The bad news is my fuel pump failed this morning with the wife in the ar. The bad news is we were about 3 miles from home. The good news is a nice lady stopped and took us all the way to our driveway.
I figured it was the pump as I had over a half tank of gas and the fuel filter was dry. When I started looking at the pump to see what style it was I found the small shaft that the fuel pump arm pivots on sticking out the side of the pump body.
You would think that would pin or brad that little shaft.
Stephen\r\nChandler, Az
Post Post subject: Re: Fuel pump failure
Posted: Mon Nov 02, 2009 12:48 AM
They leave that for use to do. On top of that I silicone both ends. Often you don't get lucky and find the pin.
chickenpants
chickenpants
Posted: Mon Nov 02, 2009 07:57 PM
Thanks for the tip Perri. I repaired the fuel pump this morning and it's working great again. I went with JB Weld for two reasons:
1) For esthetic reasons as it is almost the same color as the pump. And,
2) I didn't have any silicone but had three un-opened packages of JB Weld Smile
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1981 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3858 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion In & Out Oil Pump 0 wideopenmotorsports 1729 In & Out Oil Pump
 Wed Mar 23, 2011 03:03 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel Filler Ideas? 4 catchbats 6673 Fuel Filler Ideas?
 Sat Jul 11, 2009 09:04 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion main fuel line leak... 6 Kev_n_AZ 3296 Re: main fuel line lea...
 Fri Dec 05, 2008 04:25 PM
Kev_n_AZ View latest post
