Latest: jor_dang420
Overall: 3597
Visitors: 94
Total: 94
29: Event Calendar
31: Event Calendar
37: Event Calendar
45: Event Calendar
47: Event Calendar
61: Home
71: Pictures
76: Pictures
79: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- NEW MEMBER QUESTION. HELP!
shownuff1980
shownuff1980
Post Post subject: NEW MEMBER QUESTION. HELP!
Posted: Thu Sep 10, 2009 09:32 AM
hey guys im new here and just have a question. first off i have a 1971 stand. bug that ive decided to make a baja but the problem is, is that when i baought it it was lowered (hoodride lowered) and im not sure how to get the rear back to the right heigth? the front is stock but the p.o. was running the car with no shocks so it is also low right now. should i raise the rear back to stock or raise it higher and how. ( i think i should of posted this in susp. topics??) o well any advise would be great. thanx.
Posted: Thu Sep 10, 2009 03:05 PM
First off, welcome to the site!
To raise your rear end, you should only need to reindex the torsion bars. It's not hard to do, just kinda tedious and time consuming. The nice thing is you shouldn't need to spend any $$$ to do this, unless maybe your torsion bushings are shot, but they're cheap. BE CAREFUL is the main piece of advice, as torsions can be "pre-loaded", but since your car is lowered, I don't think it's possible that they're preloaded.
Here's a link I just found doing a Google search for "reindexing VW torsions."
Reindexing VW torsions
Posted: Thu Sep 10, 2009 03:08 PM
Oh- and you can adjust your front end up slightly as well, but you'll probably want to consider a "cut and turn" on your front beam. Basically, you cut your front beam in half, and weld in adjusters to be able to control the torsion (and lift) of the front suspension. Lowered beams are also "cut and turned," but the adjusters are clocked the opposite direction so you can adjust them to take OUT tension which will lower the car.
Hope that makes sense!
shownuff1980
shownuff1980
Posted: Thu Sep 10, 2009 06:17 PM
yes it does thank u very much. i'll give it a try. good search skills i searched all over before i posted this but couldnt find anything. i found one on utube that looked the same as mine but it was a type 3 that he was lowering so it kind of gave me an idea. thanx again.
No new posts New Members New member from Houston area
Lurking, learning, and searching
0 Mazda_wes 2424 New member from Housto...
 Tue Feb 28, 2017 07:36 AM
Mazda_wes View latest post
No new posts New Members New member from Mexico! 2 dudegdl 3051 New member from Mexico...
 Sat Nov 21, 2015 07:38 PM
No new posts New Members new member !! 2 joseph53 2870 new member !!
 Thu Oct 08, 2015 08:05 PM
No new posts New Members New/old member 2 Bajaha 2668 New/old member
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 8545 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
