Visitors: 111
Total: 111
03: Event Calendar
09: My Account
46: Event Calendar
58: Event Calendar
67: Home
82: Event Calendar
104: Home
FABINC 5-1600 Build
1 2 3 4 5 6 7 8 9
Posted: Sat Jun 30, 2012 07:23 PM
Cage and skid plate installed. Needed to change a few things with the wiring and install the tail lights/turn signals.
Alternator light on dash won't go out, but the voltmeter shows charging. Will troubleshoot that next.
64vwbug
64vwbug
Posted: Sat Jun 30, 2012 07:24 PM
Let's go for a ride!!!
Posted: Sat Jun 30, 2012 10:04 PM
Well its about time I cant wait to go for a ride in it.
Posted: Sat Jun 30, 2012 11:52 PM
Had an idea for a window scoop to get air into the oil cooler. I put the oil cooler in the window with a fan on it and then created a scoop.
$12 WRX cheapo hood scoop and $5 plexi glass from home depot.
BEFORE:
AFTER
73square
73square
Posted: Sun Jul 01, 2012 02:05 AM
That looks cool! Good job! -two thumbs up for what its worth... Smile
That's done - Next!
Posted: Sun Jul 01, 2012 03:39 AM
that turned out good
blubaron66
blubaron66
Posted: Sun Jul 01, 2012 03:53 AM
great looking baja man... just read your entire thread and I am impressed... did you do the fabrication yourself on the roof rack and rockers?
Posted: Sun Jul 01, 2012 11:45 PM
WE made it around the block today. Need to adjust the clutch play a little. I have to push it too far not to grind the gears. The reverse lockout plate on the shifter I think is in backwards. Brakes are too soft. Need some adjustment there. Also a stronger spring on the carb will allow it to pop back to neutral idle quicker.
It does ride like a race car. Needs to at speed for the suspension to work. Also need to install a steering stabilizer. The rack and pinion steers very quick on the streets.
Posted: Sun Jul 01, 2012 11:48 PM
QUOTE: "great looking baja man... just read your entire thread and I am impressed... did you do the fabrication yourself on the roof rack and rockers?"
I designed the rack and a friend built it for me. The streamline nerf bars are tubing from the fence supply area of Home Depot. Bought the end caps, welded them on and ground them down. Nothing special there.
Posted: Mon Jul 02, 2012 05:00 AM
Getting it done. Looks great
VIN70
VIN70
Posted: Thu Jul 12, 2012 04:56 AM
the very first thing i did after taking my car on the first test drive, was install a steering stabilizer, its a must with a rack.
Posted: Thu Jul 12, 2012 05:04 AM
I already have one in the works. It is a little hard to control on the pavement.
Posted: Sun Jul 29, 2012 11:52 PM
Getting really, really close on this car. Spent the majority of the weekend doing all the little things.
Engine and rebuilt trans back in the car.
Wired the lights on the roof rack.
New padding for door bars, limiting straps for the rear and fender beading for back fenders
Installed amber light
Started on number plate for the rear cage. Will also hold the license plate.
Race trim seats and G-Force 5 pt. harness' installed.
Dash bolted down, tach setup and "Oh Chit" bar installed.
Still a few more things on the list. I better have it done by Wednesday!
Posted: Mon Jul 30, 2012 03:39 AM
Very impressive Tony!
Posted: Mon Jul 30, 2012 04:44 AM
Thanks.
Still need to figure out a steering stabilizer. That is the last big thing to try and figure out.
1 2 3 4 5 6 7 8 9
26 1963BAJA 3865 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 7570 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 3801 New Class 11 Build - P...
101 SuburbanLegend 115701 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 2526 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
