Latest: strike77
Overall: 3575
Visitors: 126
Total: 126
20: My Account
24: Home
25: Pictures
27: Pictures
38: Event Calendar
40: Pictures
52: Event Calendar
61: Event Calendar
65: Home
78: Event Calendar
85: Event Calendar
98: Event Calendar
112: Event Calendar
122: Drivers
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Security
Security
Paratrooper
Paratrooper
Post Post subject: Security
Posted: Mon Aug 17, 2009 05:37 AM
I am looking at a Bug and will probably take the plunge . I am most worried about the security of engine parts since that area seems to be vulnerable to those low lifes that often shop using the "five finger discount". Bottom line : Is there a product that can discourage folks from leaving me stranded at Wal-Mart ? Thank you .
Tom in Kingman Arizona
Posted: Mon Aug 17, 2009 09:35 AM
Replace it with a Ford engine once it's VW engine is stolen. That is what I did...Takes less than 5 minutes to steal the VW engine.
I Think there is still a special bolt called and engine lock you can buy from chirco's
1915cc_Street_Rail
1915cc_Street_Rail
Post Post subject: Re: Security
Posted: Mon Aug 17, 2009 08:30 PM
I am really interested in how you did this and what you used. I don't want to hijack this thread so could you PM me some info.
As far a securing you engine I've never tried it myself, but maybe a couple of well place tack welds or cover the bolt heads with JB weld. Makes it harder for you to take out the engine if you need too, but it would make it really hard to remove in the Wal-mart parking lot.
Chenowth sand rail / 1973 Squareback / 1971 Bus / 2011 Jetta / 2011 Jetta SportWagen
fabinc
fabinc
Posted: Mon Aug 17, 2009 10:45 PM
I have seen guys use wire cable and make chokers that go around each head that get looped through tie-ins on the rear tube (torsoin tube) it's something you can make yourself if you have the right crimpers from the Depot. It has worked at the dunes for these guys for years. The midnighters would have to have a pair of bolt cutters with them to get it out then. Which if you think about it, if they want it bad enough - they will just take the whole car. Or if they can't get what they want, they will just trash what they can't take. Either way they are douchebags! ! !
FunAssBuggies (FABINC.) Gilbert, AZ. (480)-219-2584
1915cc_Street_Rail
1915cc_Street_Rail
Posted: Tue Aug 18, 2009 12:00 AM
Speaking of taking the whole car, i just remembered my brother had someone attempt to steel a baja the he had. Seems all you have to do is hook the positive terminal of the coil to a rear tail light then turn the lights on and push start the car and away they go. The thing that saved him though was that he had the mechanical fuel pump bypassed with an electric pump that only ran with the key on. He found his bug parked in another area of the lot with the light on an that is how he figured out what happened.
Posted: Tue Aug 18, 2009 12:37 AM
honestly that is just plain funny man
i would have crapped my self if i saw my baja parked in a different spot then where it should have been lol
Posted: Tue Aug 18, 2009 08:52 PM
My brother used to do that to me all the time in high school. My beater Camaro did not need a key to start, he would take it while I was in school or practice, usually bring it back after running it almost out of gas. One time he got wasted and fell asleep at home. I walked 2 miles home and found it there. I was quite ticked off.
Paratrooper
Paratrooper
Posted: Wed Aug 19, 2009 03:50 AM
Well , I did it . I bought it today . It's a '69 with a "cleaned up" 1600 . I saw cleaned up since when I was younger old engines were bored just a tad to clean up the walls . This is right at 1635 . As to my first post I was worried about componants being taken . Things like carb , generator etc.. I will need a roof rack for hunting trips that will last a few days . Light stuff BUT not a cheapie . The tires are totally new and I got 4 more to boot . I'll get back with more info as soon as I get "nitty gritty" with it . I bought it without a whole lot of looking since I know this person very well . If there is anything that needed noticing it's the fact that I wouldn't want to pay him by the hour . He agonizes over stuff and will not allow anything to be called FINISHED until it is as perfect as can be . What I can be sure of so far is :new engine , new tires and at least 150 hours labor . I'll get back with info/questions soon . Thanks .
siacs
siacs
Posted: Wed Aug 19, 2009 04:10 AM
Pictures Please
Paratrooper
Paratrooper
Posted: Wed Aug 19, 2009 04:54 AM
I will have it home tomorrow . My wife is the camera guru and will take them ASAP . It is not a showboat but it has potential . The paint job is amatuer but it was bought for getting to hunting/prospecting spots that have heretofore eluded my .44mag./metal detector . Beauty was not a consideration . I do however , promise to keep it as clean as possible .
Posted: Wed Aug 19, 2009 11:26 PM
looking fiorward to the pictures
Paratrooper
Paratrooper
Posted: Thu Aug 27, 2009 09:46 PM
I have the pix but can't seem to find out how to post them . It says that I CANNOT attach files but I don't know if that means pix .HELP .
Posted: Fri Aug 28, 2009 01:58 AM
you got to make like a photo bucket account and then you go to the picture and there is a image code and you can copy and past it into the txt box and then click submit and the pictures should be there.
Posted: Fri Aug 28, 2009 09:11 PM
if you have photo bucket use this little to add them or just go to the phot section and post you pictures.
Paratrooper
Paratrooper
Posted: Sat Aug 29, 2009 01:47 AM
I got it in . It's picture 153 . Thanks
