Visitors: 159
Total: 159
07: Event Calendar
15: Pictures
18: Pictures
19: Pictures
20: Pictures
23: Pictures
25: Pictures
27: Event Calendar
41: Pictures
46: Pictures
54: Event Calendar
62: Pictures
70: Pictures
71: Pictures
74: Event Calendar
80: Pictures
92: Pictures
96: Pictures
102: Pictures
104: Pictures
110: My Account
114: Pictures
116: Event Calendar
123: Pictures
127: Event Calendar
135: Event Calendar
138: Event Calendar
139: Pictures
141: Pictures
149: Event Calendar
152: Event Calendar
155: Pictures
157: Baja Forums
159: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- stupid leaking gas tank gaskets...
Brettucks
Brettucks
Post Post subject: stupid leaking gas tank gaskets...
Posted: Fri Aug 07, 2009 03:40 PM
Hey all-
when full the stock tank is leaking out the top where the sender goes in... bought a new gasket... went to replace it and found two gaskets aready there, glued together... thought to myself 'well thats the reason, this should solve it'.... of couse with the new single gasket it leaks slightly worse... had to drive around aimlessly to get rid of some gas so my garage wont blow up if i hit the door opener...
How have yall fixed this??
-Brett
kyle_pc_75
kyle_pc_75
Posted: Fri Aug 07, 2009 04:28 PM
I got a new rubber gasket from Chirco's, seemed to work just fine without any sealant or anything. Have you checked the mating surfaces of the tank and sender for irregularities, dirt, etc? Also make sure you tighten the sender in a criss cross pattern like you do with your lugnuts, and try to torque them all evenly.
Kyle
Posted: Fri Aug 07, 2009 09:11 PM
I think that there is 2 types of senders and gas tanks. Look and make sure you sender does not have the rolled over edge. If it does it might be hitting the tank before the prsure is put on the gasket. That is why it has a double gasket vs. a single to make sure the edge of the sender is not hitting the top of the tank.
Brettucks
Brettucks
Posted: Fri Aug 07, 2009 10:38 PM
I did not notice any contamination or bent sealing surfaces.... and I did criss cross the tightening... havent checked for the 'interference' of parts...
got down to 3/4 tank and will look into it...
thanks for the ideas...
-Brett
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1714 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Help Needed --> Gas Tank Safety!! 2 jk97 2298 Help Needed --> Gas Ta...
 Wed Jul 13, 2011 06:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Engine leaking gas while parked... 8 pschneider 6139 Re: Engine leaking gas...
 Sat May 01, 2010 12:10 AM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Leaking centerlines.. 9 Brettucks 3600 Re: Leaking centerline...
 Wed Feb 03, 2010 01:32 AM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Thinking about getting a Long Range 16 Gallon Fuel Tank 10 siacs 3738 Re: Thinking about get...
 Sat Oct 18, 2008 03:43 AM
siacs View latest post
