Latest: ecthemc
Overall: 3567
Visitors: 138
Total: 138
07: Event Calendar
41: Event Calendar
71: Pictures
78: Event Calendar
94: My Account
113: Event Calendar
114: Pictures
128: Event Calendar
136: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My baja project
My baja project
1 2 3 4
big0067
big0067
Post Post subject: My baja project
Posted: Thu Jul 30, 2009 02:10 AM
I just started my 1970 baja project i just wanted to thank everyone on this site for the great info ive owed a lot of vw.But this is my first total from start to finsh project that ive tryed.But I ordered a bugeye baja kit,header,3in body lift,spritbars,bumpers,from chircos which was some more great info that i found out from this site.Heres my starting pictures ill sent more of my progress.but to everyone here on this site thaxs.
Big0067
p.s i hope thats the rite pictur im new at computer stuff Confused
Post Post subject: Re: My baja project
Posted: Thu Jul 30, 2009 06:34 PM
I can't seen to open up the link.
big0067
big0067
Posted: Fri Jul 31, 2009 03:22 AM
[img]C:\Documents and Settings\Joe\My Documents\My Pictures\img.gif[/img]Ithink i figured it out my 1970 stock beetle.Before the cutting begins
Posted: Fri Jul 31, 2009 04:14 AM
Your getting closer but when I click on it it still does nothing.
Posted: Fri Jul 31, 2009 06:38 AM
You need to use a host site like photobucket.com
big0067
big0067
Posted: Sat Aug 01, 2009 01:41 AM
[img]http://http://[/img]ok let see if that works before pictures
big0067
big0067
Posted: Sat Aug 01, 2009 01:54 AM
Posted: Sat Aug 01, 2009 02:02 AM
I use Photobucket at www.photobucket.com
The first step is uploading your picture, if you have more then one then click on the "add more images"
Find where the picture is in your computer, I have a folder in the computer set aside for just pictures to upload. Click on that add more if needed.
Once you have the picture uploaded got to the picture you want left click on the [img] which will highlight it, right click on the highlighted line and select copy.
Then left click onto your AZbaja where you want it and hit control v. Put an empty line between multiple photos.
Posted: Sat Aug 01, 2009 02:28 AM
Welcome! And the link still does not work. Try photobucket or flickr and copy/paste the link from there.
What part of West-by-God are you from? I'm about an hour from Charlestown, but in Northern Va.
big0067
big0067
Posted: Sat Aug 01, 2009 03:23 AM
hope i have better luck with my baja project than i do try to post pictures
big0067
big0067
Posted: Sun Aug 02, 2009 08:22 PM
ok im rebuiling my motor in my bug i need a new motor to go with the bus trans axe i just got ok im going just put 88mm piston and jugs and a bigger cam to my stock 1600 can a run a turbo with that or do i have to do something specail to run a turbo
siacs
siacs
Posted: Sun Aug 02, 2009 09:43 PM
You can but I would look at some posts from perrib and others I am sure they will chime in
Posted: Sun Aug 02, 2009 09:55 PM
There is a lot to do to build a turbo engine and have it last.
One of the cheapest, simplest to build, good running, longest lasting engines is a 74 mm stroke x90.5 bore which yields 1904 cc. If you don't want to bore the case a 82x85.5 makes a 1883. but you will need to clearance the case or have it done. Combined with a W 100 cam and a single two barrel 40 mm Weber and you have plenty of power for off roading and an engine that should last 60-100k. DPR machine.com can set you up with the crank and rods.
Have you visted Photobucket.com yet. An account there should fix your photo posting trouble.
Posted: Mon Aug 03, 2009 12:42 AM
you need to link to a .jpg for a picture to show up. like this
wideopenmotorsports.us...es/326.jpg
You been linking to a page like this.
wideopenmotorsports.us...s/326.html
see the html at the end. it needs to be a .jpg or some sort of picture type file.
how to get it right click your mouse over the picture. Click properties at the bottom of the bar. It ill bring up the true URL address of the picture.
big0067
big0067
Posted: Wed Aug 05, 2009 03:58 PM
s584.photobucket.com/a...ure023.jpg ok heres my pictures finally thats Perrib well i got all kind of parts from Chirco net pictures it will look a hole lot differt Very Happy
1 2 3 4
4 Admin_AzBaja 5073 Baja Bugs on Wiki need...
1567 mufasavnvmc 839651 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 206034 Re: Baja sightings
Off-road event
1 wideopenmotorsports 150 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
1170 Dalton 253186 My 69 project
 Wed Dec 06, 2017 01:38 AM
