Visitors: 115
Total: 115
27: Event Calendar
33: Pictures
50: Home
60: Event Calendar
84: My Account
95: Home
98: Home
104: Home
108: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- building my first baja.....i could use some advice
vindeta
vindeta
Post Post subject: building my first baja.....i could use some advice
Posted: Sat Jun 20, 2009 04:16 PM
well guys i finally got my first car its a 1975 regular bug.
has very minor rust (for ohio) and came with a bunch of new parts.
this is my first restoration/build ever and i have a ton of questions about bugs and restoring in general.
heres everything i got.
my new toy!!
95950 miles
its missing the engine.
brand new running boards and heater channel bottoms
i also got all new body, fenders, and door seals......cal look Very Happy
two new pans
last night and this morning i took the fenders off, took out the back seat, all the rest of the vinyl panels,removed the seat belts, pulled the gas tank....the tank is filled with rust and when you shake it around you can hear all the dust, rust and dirt moving around inside it.
shot of the back seat its imaculate. im going to get bucket seats for the front.
heres all the wiring its all in almost perfect condition.
another problem with the steering, it slips sometimes, mostly it slips when you crank the wheel all the way to either direction, like right before it stops turning it will slip, but when the steering gets really hard it slips too.
is my steering gear box bad?
kyle_pc_75
kyle_pc_75
Post Post subject: biulding my first baja.....i could use some advice
Posted: Sat Jun 20, 2009 04:25 PM
Congrats. Finding decent bugs is tough around here, too. Looks like a good project. If I were you, I'd completely strip it down and take care of all the rust first. That'll take a while and you can sell the stock parts you won't be using and save up your money for all the other parts you'll need!
Kyle
Post Post subject: Re: biulding my first baja.....i could use some advice
Posted: Sat Jun 20, 2009 07:45 PM
The rims are EMPI 8's ( if you were closer I'd take them off your hands.)
The computer was for fuel injection.
I don't know about the quality of the pans.
The steering shaft is normal. It's designed to colapse in case of a head on.
In most cases you can clean up a tank, but it's not always worth it.
Posted: Sat Jun 20, 2009 08:00 PM
Is that a custom convertable top in the picture?
has very minor rust and came with a bunch of new parts.
bad?
vindeta
vindeta
Posted: Sat Jun 20, 2009 08:13 PM
the umbrella??
pity i dont have the engine to go along with that computer.
i was hoping to sell the running boards and all the rest of the stuff i dont need, exept the rims i like them to much Smile , but my dad wants me to restore it to stock form and not baja it so he said to hang on to the parts for now, i really dont want to do that because i will have to do SO much more work because the stock fenders are rusted around the bolt holes and two of the bad rust spots are in an area that i would cut of if i baja'ed it.
im still planning to baja it but i just have to convince my dad that it doesn't ruin the car first.
i just spent two hours with as air compressor, vacume, and hammer, cleaning out the whole car.
theres 3-4 spots that are pretty much gone because of rust but other that that its in good shape.
im planning to go out and take the body off and start my long vigil against rust.
Posted: Sun Jun 21, 2009 04:14 AM
one piece of advice that i can give you is if your building a baja do it right the first time so you dont have to do it again and spend more money than you would have if you would of just spent the extra cash and did it right the first time
just my .02
good luck !!!
bro
vindeta
vindeta
Posted: Mon Jun 22, 2009 08:43 PM
i took the body off and now im working on the chassis.
on this side of the back i just need to reweld all the seams on the "arm" and it should be good.
the other side is a little rougher.
i had to cut the smaller piece out so im going to replace it with another L shaped piece just like it.
im not sure what the guy before me was thinking but he cut out almost the whole weld joint between the "arm" piece and the main beam.
i think i should be able to weld it shut or use a patch/brace and weld it back together.
the front is another thing though its pretty rusted out.
left side is the worst
im hoping to use patches and weld it all back together.
i might have to cut a little more of the metal out.
do yall think that will work? like will it be structurally sound?
bottom of the whole frame head.
other side isnt atall as bad
ill just patch the holes and weld a plate on the bottom.
im going to coat the whole chassis with some kind of bed liner.
the kind that treats and prevents rust would be awsome but i already hav a couple cans of rhino liner so ill have to check into the prices.
will all my ideas will work? and will everything be solid?
vindeta
vindeta
Posted: Mon Jun 22, 2009 08:54 PM
these pieces came with the car too....what are they exactly?
#1[img][/img]
#2[img][/img]
this one is really weird.
made out of rubber and its shaped like a big funnel/cone.
#3[img]\[/img]
#4[img][/img]
#5[img][/img]
#6[img][/img]
this is all the heater parts right?
#7[img][/img]
is this everything for the heater? or am i missing parts for it??
vindeta
vindeta
Posted: Mon Jun 22, 2009 09:06 PM
the body its rusted out pretty bad around the edges of the whole bottom of the car.
front left
and along the bottom of the left side
the right side is alot worse than the left. i dunno why but it is
front
side
the inside is pretty rough in the back but thankfully the worst spot is covered by the rear seat so it doesnt have to look pretty.
[img][/img][img][/img]
the front left side is pretty good but the right side is a little rough
do you guys think all the holes are patchable??
i have to cut a fair amount of metal out of the really bad spot in the back and then put in a massive patch.
opinions, thoughts, advice ??
vindeta
vindeta
Posted: Mon Jun 22, 2009 10:41 PM
well as if i didnt get a sweet enough deal on the bug i bought, a guy gave my grandpa this baja for parts
its pretty rusted out but alot of the parts are still good.
so for free i got
a good set of rims and good back tires
a baja kit off the car
the only problem is its a bug eye kit and the more i look at them the less i like the "bug eye" look, but for free you cant beat it....and maybe it will grow on me.
4 fairly new KYB gas shocks
a good gas tank, swing axle tranny, aftermarket thumb style shifter, pedal asembly, and lots of random cables and other parts that i am missing on my bug.
kyle_pc_75
kyle_pc_75
Posted: Mon Jun 22, 2009 10:44 PM
I hate to break it to you, but that car is pretty rough. It's worse than my DD, which I've decided to just drive and enjoy because I didn't want to go through the trouble of repairing all the rust. You'll have to grind/cut everything away, see what's left and decide if you want to pursue the project then.
Having said that, pretty much anything is repairable. It's a matter of patience, skill, time, etc. Look through the paint/bodywork forum over at the Samba. Lots of good info over there. I've also heard the BugMe videos are good for learning about repairing this sort of damage.
For some good news: Lots of those odd/weird parts you were asking about are fuel injection/emissions pieces and will fetch a good price to an enthusiast looking to restore his car. It looks like you got a good haul in parts, so you can at least sell that and have some money to put towards what you want.
Good luck!
Kyle
vindeta
vindeta
Posted: Mon Jun 22, 2009 10:52 PM
your right it is pretty rough, but compared to most other bugs around here (ohio) its in really good condition, and for the price i paid it was a pretty good deal.
thanks alot for the suggestion ill go check it out.
Posted: Tue Jun 23, 2009 04:53 AM
That car aint that rough!
Hell, its a baja, its not suppose to be pretty.
And you got a sh!t ton of parts!
Im from upper michigan, and i know about rust, it sucks.
Just a question, but how old are you?
vindeta
vindeta
Posted: Tue Jun 23, 2009 04:52 PM
im 16 so that puts us in the same boat i guess, the poor mans canoe lol
btw nice baja i like yur paint scheme.
Posted: Tue Jun 23, 2009 07:27 PM
nice, We have another young gun of the baja world.
Im 15 years old, and thanks!
5 Admin_AzBaja 8645 Baja Bugs on Wiki need...
1569 mufasavnvmc 1072760 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 258387 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1406 FREE VW BAJA'S
0 Northmountainauto 2271 Shop Baja
