Visitors: 73
Total: 73
38: Event Calendar
55: My Account
61: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- interior
interior
cperry2704
cperry2704
Post Post subject: interior
Posted: Sun May 31, 2009 08:17 PM
what is the best glue/contact cement i can use to put in a headliner?
Posted: Sun May 31, 2009 08:46 PM
I use weld-wood contact cement . two or three coats. let dry 20 min each coat. On the steel & headliner. And then you can work out the haedliner.
cperry2704
cperry2704
Posted: Sun May 31, 2009 11:57 PM
i was planning on using carpet forr the headliner....will that still work?
Post Post subject: Re: interior
Posted: Mon Jun 01, 2009 04:04 AM
I got this stuff from my local auto parts place that is made for headliner/carpet. It was about $8 a can but worth it as it was spray on and didn't seap through the headliner holes and certainly easier to clean up than some of the other glues.
I know your using carpet so maybe the other glues will be ok, so long as the carpet isn't not porous.. If it is, you'll get some bleed through.
No new posts VW Volkswagen & Baja Bug General Discussion Headliner, interior upholstery
Wanted
1 desertbaja 1428 Re: Headliner, interio...
 Mon Sep 03, 2012 06:00 PM
No new posts VW Volkswagen & Baja Bug General Discussion Question about all those interior holes... 10 mike240 4808 Re: Question about all...
 Sun Nov 30, 2008 10:18 PM
BajaMike65 View latest post
No new posts Projects and Builds Joxracing interior update 3 joxracing 4480 Re: Joxracing interior...
 Sat Aug 23, 2008 05:49 AM
danjones333 View latest post
