Latest: George
Overall: 3576
Visitors: 100
Total: 100
15: My Account
40: Event Calendar
47: Event Calendar
56: Contact Admin
76: Event Calendar
81: Event Calendar
91: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- visual stimulation
visual stimulation
The following users give thanks for this topic hoserbug - Fri May 22, 2009 07:09 PM
Colesifer68
Colesifer68
Post Post subject: visual stimulation
Posted: Fri May 22, 2009 04:05 PM
well guys, as some of you may know i had my baja bug taken down to a fab shop in gilbert called FAB Inc. to get it built to race 5/1600 in the whiplash serries. well i just got these pics in my email and i am so stoked...full tube frame chassis, front and rear bumpers, seat mounts, rack and pinion, brand new link pin front end, fox 10' 2.0 emulsions in front, fox 12' 2.0 rezzi smooth bodys in rear. trailing arms boxed in, all new wheel bearings and seals, new hd hubs, so much more i cant even think of right now. anyway, the fab is done minus a few tabs for mounting a couple things. i need rear tires, seat belts, and window nets. the car is otherwise done for the most part. we are looking to have it turn key in about 2 weeks. the work is absolutly flawless.
if you need fab work done or even want to buy a turnkey race car give James Gusty a call at 480-219-2584
let me know what you guys think!!
thanks,
Cole
kyle_pc_75
kyle_pc_75
Posted: Fri May 22, 2009 04:30 PM
Looks like crap. Wink
HA! That thing is way cool. I love that full chassis/cage, but how are you going to get the engine in? I take it they're going to make the engine cage removable?
Kyle
Colesifer68
Colesifer68
Posted: Fri May 22, 2009 05:36 PM
the cage is removeable. it slides on to a smaller size tube and gets bolted in place. work is real nice. cant wait to drive it!!!
thanks
Bajaed
Bajaed
Post Post subject: Re: visual stimulation
Posted: Fri May 22, 2009 10:03 PM
Thats bad a$$!! How about some pics of the rear upper shock mount and cage in that area when you get it back?
Grunt-0341
Grunt-0341
Posted: Fri May 22, 2009 10:08 PM
Looking Good!
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
siacs
siacs
Posted: Fri May 22, 2009 10:22 PM
That is so sweet
Posted: Sat May 23, 2009 01:35 AM
SCHWEET!!
One question tho.... It appears to me that the steering wheel is set back a bit, won't that make it difficult to shift gears?
VIN70
VIN70
Posted: Sat May 23, 2009 01:44 AM
locutisj wrote:
SCHWEET!!
i was thinking the same thing...are they going to fill that monster hole, that was cut for the steering shaft?
Posted: Sat May 23, 2009 01:57 AM
It is looking good.
Colesifer68
Colesifer68
Posted: Sat May 23, 2009 02:24 AM
thanks for the comments guys.
im not sure how that is going to work. im going down there tomorrow to do some work on it. i will have to see how i fit in there. i am pretty tall and have a long reach so it may be great
thunderklees
thunderklees
Posted: Sat May 23, 2009 02:51 AM
Just curious why you didnt go with coilovers?
Colesifer68
Colesifer68
Posted: Sat May 23, 2009 03:46 AM
coilovers are illegal in the 5/1600 class
thunderklees
thunderklees
Posted: Sat May 23, 2009 06:09 PM
Well thats a pretty good reason. Looks like a lot of fun!
Colesifer68
Colesifer68
Posted: Sat May 23, 2009 09:55 PM
ya the car should do great. it has alot of suspension under it so im sure it will be a good ride. im hoping to be able to take the car out in the next couple weeks. just need harnesses and window nets.
Posted: Sun May 24, 2009 01:01 AM
i saw that car before on gilbert and williams field before is that your place or someone elses
