Visitors: 149
Total: 149
09: Home
16: Event Calendar
39: Pictures
79: Home
92: Home
117: Pictures
120: Home
125: Pictures
136: My Account
137: My Account
138: My Account
139: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Tires rubbing.
Tires rubbing.
thunderklees
thunderklees
Post Post subject: Tires rubbing.
Posted: Wed May 06, 2009 05:09 AM
My front tires are rubbing the through rods on the front end when I turn hard. I have 4x2 1/2 arms. The tires are 30x9.5. And the wheel are 6" wide.
It only rubs on very hard turns but made a little groove in my new tires.
I was thinking about going to 235/75r15. It shows them on treadwright as 9.1 inches wide and my 30x9.5 are showing 9.4 wide.
Think that will be enough? I dont want to go too much smaller?
Any other ideas?
Thanks in advance. This website has been a great help on all of my projects!
Posted: Wed May 06, 2009 03:29 PM
How about the wheel width? That seems pretty wide for fronts- might also be part of your problem. If you're stuck on the width though, a different offset would help also. Of course, leave it to me to point out the most expensive option!
thunderklees
thunderklees
Posted: Wed May 06, 2009 04:13 PM
I am not set on the width. I just dont to go go any smaller tire diameter.
I wouldnt mind finding a nice set of aluminum wheels. Maybe I can check some prices of 15x5 wheels.
Posted: Thu May 07, 2009 12:46 AM
I think that ther is a screw or 2 on the steering box were you can set your end stops. look for end stops that you can adjust. My car is no longer stock so I'm not sure any more.
thunderklees
thunderklees
Posted: Mon May 25, 2009 08:08 PM
If anybody else had a similar problem I found 3/8 inch wheel spacers on ebay. They were only $12 each and did the trick.
68 Baja Beetle project build
5 Scrappy68 3222 Re: Lets talk tires.
 Fri Dec 14, 2018 03:45 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 2500 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
vw baja stock tires
7 iBeastSousa 4097 tires
 Tue May 27, 2014 10:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3462 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
25 Rigger 12455 I am looking for some ...
 Fri Oct 05, 2012 03:30 AM
Rigger View latest post
