Latest: xbluegto
Overall: 3573
Visitors: 209
Total: 209
55: Event Calendar
72: Event Calendar
124: Pictures
134: Event Calendar
149: Pictures
152: Event Calendar
158: Baja Forums
172: Baja Forums
176: Baja Forums
178: Baja Forums
185: Baja Forums
197: AMAZON.com
198: Baja Forums
201: Baja Forums
202: Baja Forums
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- lake plesant
lake plesant
1 2 3 4
The following users give thanks for this topic Anonymous - Tue Mar 17, 2009 09:49 PM
Post Post subject: Re: lake plesant
Posted: Fri Mar 20, 2009 12:59 AM
Colesifer68 wrote:
im going to put the engine cage and skidplate on the car and im goin to make the trip. i think it would be a great first maiden voyage
They on yet??
Colesifer68
Colesifer68
Post Post subject: lake plesant
Posted: Fri Mar 20, 2009 08:29 AM
got the cage on..i thought i posted pics. need to do a helicoil on one of my exhaust bolts. double check my valves and get my lights workin then i will be 100%
im having one hell of a time with the lights lol
Posted: Fri Mar 20, 2009 04:12 PM
thesamba.com has excellent OEM wiring diagrams in color.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 06:03 PM
great!! ill look into that here shortly. this thing has been changed around so much i hope the oem wiring is still there!!
Posted: Fri Mar 20, 2009 06:25 PM
If the wiring is a disaster. It is better to make a new harness mimicing the factory colors or get a new harness from BAP or Circo.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 06:56 PM
im sure i will figure it out. dont really want to drop another 150 on a wireing harness.
i got the valves done...im glad i double checked. some were loose and some were tight. i guess i was doing it wrong the first time. de de de.
so that is handled. Darryl tuned my carb for me yesterday so now the only thing i need is my lights and do a helicoil in the cylender.
i have the cage on but didnt have a skidplate put on yet. im going to need to weld on some tabs for me to bolt it to the cage.
once these things are finished im going to get it registerd and i will be ready to rock. which run do you think would be better for me to take this thing out to? lookin to put it threw the motions but dont want anything extreme.
Posted: Fri Mar 20, 2009 07:30 PM
Stick cloes to home the Rolls, Sycamore Creek are close and have all kinds of terrain.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 07:34 PM
where are those at? i could also tow it to where i want to go and tow it back incase something does happen.
Posted: Fri Mar 20, 2009 07:54 PM
Plently of room to park a truck and trailer is availiable at both areas. You do need a permit to park at the Rolls. If you take it easy nothing should break. You should take oil, clutch and acc cable, fan belt, vc gaskets, jack, spare tires and tools. We can try to get some otf the dormant Az Baja and rails out for a group ride.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 08:07 PM
that would be cool. where do i go to get a permit??
got tools oil scissor jack and bottle jack have chain(not sure if its strong enough but its what i have and its a light car) just need to get a belt, extra cables and a spare..im going to need a roof rack soon!!
Posted: Fri Mar 20, 2009 08:37 PM
Sounds like your almost there. Bring some spare nuts, bolts, washers and lug nuts/bolts. Bugzilla or I can get the wiring going if it gets to much for you. Final prep is to check all the nuts and bolts on the suspension and engine. Several Circle Ks sell them as does the Baja gas station on 87.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 08:57 PM
i will go over the suspension this evening. the bolts on the engine are tight...i am missing a bolt on the top on the engine on the driver side. i also have transmisssion straps that i want to put on before i go rhomp it.
i would love to get some help on the wiring. i have been messing with the damn things for so long i cant even make sence of it anymore. i have everything in the same place it was when i got it but im just about over it.
im going to ace hardware today some time and going to get a few bolts and whatnot.
Posted: Fri Mar 20, 2009 09:06 PM
An upper and lower mid transaxle strap is a must. In a hurry to ride I left it out on my first rail build. We drove 5 miles back to the trailer with a large rock jammed between the transaxle and gas tank.
Colesifer68
Colesifer68
Posted: Fri Mar 20, 2009 09:10 PM
whoa. ya i need to get those on. i have 2 of them. im not sure how there going to go on. i have a front and center i think.
thats somthing im going to get bolts for as soon as i figure out how to get them on!
Posted: Fri Mar 20, 2009 09:31 PM
The piece with all the two small c bends goes under the frame horns the single hoop goes over the transaxle Two bolts hold it all together.
No new posts Events and Get Togethers World Wide Lake Pleasant 1 Dalton 1167 Lake Pleasant
 Mon Feb 27, 2017 03:25 PM
No new posts VW Volkswagen & Baja Bug General Discussion First trial ru at lake pleasant... 4 Brettucks 2807 Re: First trial ru at ...
 Thu May 20, 2010 01:32 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion playin at the lake 8 baja17 5408 Re: playin at the lake
 Sat Aug 29, 2009 03:12 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion lake plesant 0 Colesifer68 1224 lake plesant
 Mon Mar 16, 2009 04:18 PM
Colesifer68 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bartlett Lake 2 perrib 2973 Re: Bartlett Lake
 Wed Aug 06, 2008 10:11 AM
