Latest: xbluegto
Overall: 3573
Visitors: 213
Total: 213
01: My Account
10: My Account
12: Pictures
19: My Account
41: Event Calendar
44: Event Calendar
45: Event Calendar
46: Event Calendar
52: Event Calendar
61: Pictures
79: Event Calendar
94: Event Calendar
95: Event Calendar
98: Event Calendar
107: Pictures
109: Pictures
143: Pictures
150: Baja Forums
166: Event Calendar
169: Event Calendar
171: Event Calendar
172: Event Calendar
173: Baja Forums
178: Baja Forums
179: Baja Forums
181: Baja Forums
184: Baja Forums
185: Pictures
189: Baja Forums
190: AMAZON.com
191: Baja Forums
194: Baja Forums
197: Baja Forums
198: AMAZON.com
201: Baja Forums
202: Event Calendar
204: Baja Forums
205: Event Calendar
207: AMAZON.com
208: Baja Forums
209: AMAZON.com
210: Garage
212: AMAZON.com
213: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- lake plesant
lake plesant
1 2 3 4
The following users give thanks for this topic Anonymous - Tue Mar 17, 2009 09:49 PM
Post Post subject: Re: lake plesant
Posted: Tue Mar 17, 2009 04:30 PM
As long as you have ground clearance and it is dry 98% of the trail is 2wd.
It is easier to go from LP to CK as you go down the worst two spots. What exhaust do you have now. Apache Muffler can add a u bend and a muffler for a fair price.
Colesifer68
Colesifer68
Post Post subject: lake plesant
Posted: Tue Mar 17, 2009 04:43 PM
i have an empi stinger..mounting the engine cage now. the guy i got the car from is a total tool. he told me alot of bs that someone who doesnt know what theyr doing. so i had to learn very fast. i had to remove the engine cage when i first got the car cuz it wasnt straight. workin on it now.
i adjusted the valves yesterday and it runs night and day different. just doesnt want to idle now. im goin to play around with it a little more. it seems like it is still rich. i cant seem to find the volume screw on the carb while it is mounted in the car. could i be looking in the wrong place??
Posted: Tue Mar 17, 2009 05:28 PM
Air is the big screw above the small fuel screw on DS of carb, You have the best off road exhaust, go to Apache Muffler and have them weld on a u bend pipe and quiet muffler it used to be about $40.00. Save your money for a good air filter. You also need the exhaust preheat hooked up for when it is under 60 degrees outside. The nipple for the down draft tube is missing and so is a filter for the oil breather. Cages get bent first time you use it for what it is made for.
Colesifer68
Colesifer68
Posted: Tue Mar 17, 2009 10:10 PM
whats the down draft tube?? could be why i dont know what it is LOL
Are they located in mesa or AJ?? i would like to go have that done asap, its just to damn loud. i can have them get the preheat together im sure. i was going to get a new oil breather because that one is lame. some more work to do before i can take it out as of now. im going to bleed the breaks tomorrow morning and try to get the windows in and the lights working.
what kind of air filters are popular for offroad?? the cage looks great for a cheesy krylon job. im sure it will get beat up but that doesnt mean that it cant look pretty before.
Posted: Tue Mar 17, 2009 10:41 PM
It is the part going down from the stock oil breather. You can cut it flush and solder a penny to the bottom of the breather. Google can be your friend. Jeff Hibbirts book building Bajas and Buggies will be your best friend. Apache Muffler is on the north side of West Main St in Mesa. If they can not do the preheat I can. You need to get two Empi heater riser block off plates to fabricate them with.
Pre heat tube
Offroad air cleaner, These $40.00 air filters come with a chessy filter you replace it with a paper one or KN covered by 2-3 outer wears and it works almost as good as the $300 UMP filter assembly. Note the bracket to make sure it never falls off again.
Colesifer68
Colesifer68
Posted: Tue Mar 17, 2009 11:08 PM
when adjusting the fuel screw how much of an adjustment is going to be made before i will notice a difference?? will it make it idle better?? i am having a problem now after i adjusted the valves to where they need to be for it to idle correctly for a while. it will idle for a few minutes and die like its getting flooded. i will try and play with the carb a bit more and see how it works. im sure i can get it tuned in pretty well
Posted: Tue Mar 17, 2009 11:11 PM
Turn the screw 1/4 turn at a time it takes a while for the engine to react.
Colesifer68
Colesifer68
Posted: Tue Mar 17, 2009 11:13 PM
thats what i was thinking..im use to tuning an rc car engine and it goes by hour increments...no wonder its taken forever lol
Colesifer68
Colesifer68
Posted: Wed Mar 18, 2009 02:55 AM
i got the carb adjusted alot better then it was. it was definatly way off. still sputters in the mid range of the powerband. maybe still rich??
here are a couple pics of the engine cage i took this morning. i also got a pic of the suspension i have in the rear. let me know what you think.
thanks
Posted: Wed Mar 18, 2009 03:19 AM
Could be Rich ,lean and/or improper timing. Your suspension will work as long as you don't go to fast off road with it.
Colesifer68
Colesifer68
Posted: Wed Mar 18, 2009 03:22 AM
maybe you could help me get it set properly. i may be off on the timing because it is still backfiring pretty bad.
Posted: Wed Mar 18, 2009 03:25 AM
Have you done a compression test yet?
Colesifer68
Colesifer68
Posted: Wed Mar 18, 2009 03:28 AM
no sir. dont have the tools for that.
Posted: Wed Mar 18, 2009 04:02 AM
It alway nice to check the basics. I know the compresion came up when you said it ran better when you adjusted the valves.
Colesifer68
Colesifer68
Posted: Wed Mar 18, 2009 04:25 AM
i would have to go get a compression gauge. i will try and play with some more tuning and see if i can get it to run better.
No new posts Events and Get Togethers World Wide Lake Pleasant 1 Dalton 1167 Lake Pleasant
 Mon Feb 27, 2017 03:25 PM
No new posts VW Volkswagen & Baja Bug General Discussion First trial ru at lake pleasant... 4 Brettucks 2807 Re: First trial ru at ...
 Thu May 20, 2010 01:32 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion playin at the lake 8 baja17 5408 Re: playin at the lake
 Sat Aug 29, 2009 03:12 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion lake plesant 0 Colesifer68 1224 lake plesant
 Mon Mar 16, 2009 04:18 PM
Colesifer68 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bartlett Lake 2 perrib 2973 Re: Bartlett Lake
 Wed Aug 06, 2008 10:11 AM
