Latest: ddbug11
New Yesterday: 2
Overall: 3596
Visitors: 105
Total: 105
07: Pictures
25: Pictures
41: Home
96: Links
101: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Fuel Tank
Fuel Tank
baja?
baja?
Post Post subject: Fuel Tank
Posted: Fri Aug 18, 2006 06:29 PM
I was wonderin if anybody here has put a new fuel tank in their bug. How easy is it? And can i put on in the back where the back seat used to be? Can i do it with basic tools? Help would be greatly appreciated.
72BajaBen
72BajaBen
Post Post subject: Re: Fuel Tank
Posted: Fri Aug 18, 2006 06:55 PM
i just put a spun aluminium tank in mine. it was pretty easy. i think that putting one where th back seat is is a little more involved, but i wouldnt think that it is that hard.
baja?
baja?
Posted: Fri Aug 18, 2006 06:59 PM
where did you put yours at?
Posted: Fri Aug 18, 2006 07:20 PM
under the hood, where else ? Wink
baja?
baja?
Posted: Fri Aug 18, 2006 08:35 PM
I thought i heard from somewhere that you can mount a fuel tank towards the rear of the car.....hmm
if i did do that would it make the front way to light have any kind of steering?
azhunter
azhunter
Posted: Fri Aug 18, 2006 09:34 PM
There are tanks designed to go in the rear package tray(less desirable) and tanks designed to replace the rear seat and lay flat. Moving the tank rearwards does lighten up the front end. Fuel isn't that far off from water at appx. 8lbs. per gal so figure in that weight transfer. consider stering brakes if you do the switch.
tsutt
tsutt
Posted: Fri Aug 18, 2006 10:20 PM
FYI. water is 8.3lbs/gal., gas is 6lbs/gal.
Posted: Fri Aug 18, 2006 11:52 PM
i didn't realize that there was that much of a differance in weight... sure bout those numbers tsutt ? and if its true, why the differance ?
tsutt
tsutt
Posted: Sat Aug 19, 2006 12:07 AM
absolutly positive, different density, which is probably due to the molecular make up. you can google the specs. here's one for you, How many gallons will a 12"x12"x12" tank hold?
azhunter
azhunter
Posted: Sat Aug 19, 2006 12:17 AM
I kknew I was close on the water. Used to be fireman a few years back. so you have a 25% diff. in weight. So, 15 gal (just a guess) at 6 lbs,,,,,90 lbs would be lost in front end weight. Still quite a bit if you think about it.
Posted: Sat Aug 19, 2006 09:32 AM
part of the oil and water do not mix, fuel is lighter than water so it floats.
2nd point the guy has an airplane for his avitar, I'm pretty sure he knows it down to the gram.
Posted: Sat Aug 19, 2006 04:13 PM
Mounting a fuel tank inside an enclosed car is a bad idea, unless you plan to remove the windows the fumes would be pretty bad all the time.
69bapbaja
69bapbaja
Posted: Fri Aug 25, 2006 06:56 AM
If you do mount the gas tank inside may i suggest that you get a fuel cell. it is a double walled and it has a anti flow valve. just incase of a roll over that the gas stays in the blater. Not spling over you and your love ones.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 2017 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Help Needed --> Gas Tank Safety!! 2 jk97 2642 Help Needed --> Gas Ta...
 Wed Jul 13, 2011 06:23 AM
Replacement Possible or Not
3 jemizasi 3925 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 2175 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion stupid leaking gas tank gaskets... 3 Brettucks 3369 stupid leaking gas tan...
 Fri Aug 07, 2009 10:38 PM
Brettucks View latest post
