Visitors: 113
Total: 113
21: Event Calendar
30: Home
41: Event Calendar
42: Event Calendar
55: Home
57: Pictures
59: Event Calendar
87: Event Calendar
96: Event Calendar
98: Event Calendar
100: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- front brakes on a sandrail
Thuff
Thuff
Post Post subject: front brakes on a sandrail
Posted: Wed Jan 28, 2009 01:59 AM
Seems like most of the sandrails i find have no front brakes. i understand that most of the braking is done in the rear of one. it seems like it would be a good idea to have them if you are going to be playing off road and not on the sand. I can see the bad in having them in sand.
Has anyone driven much off road with no brakes on the front of there rails?
Posted: Wed Jan 28, 2009 05:50 PM
You NEED front brakes for general off roading. Bald tires in the sand with no front end weight usually do not work well with brakes.
Leather used to (probably still does) have 2 set ups on his rail. No brakes and spindle mounts for sand, and beefy stuff w/brakes for off road.
Post Post subject: Re: front brakes on a sandrail
Posted: Thu Jan 29, 2009 03:11 AM
The very first time I rode my rail with no front brakes the next weekend it had front brakes. Rear brakes alone are worthless on a hill. I use an adjustable proportion valve to adjust the bias. In the sand I can turn off the braker fluid to the front brakes.
1569 mufasavnvmc 1071105 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2456 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 8034 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3672 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wide Ball Joint front end? 5 Darn_Near 8806 Wide Ball Joint front ...
 Wed Sep 07, 2011 08:12 AM
Darn_Near View latest post
