Visitors: 133
Total: 133
20: Event Calendar
42: Event Calendar
44: My Account
53: Event Calendar
76: Pictures
84: My Account
95: Event Calendar
116: Event Calendar
117: Pictures
129: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- fillin in the blanks
saltyslug
saltyslug
Post Post subject: fillin in the blanks
Posted: Wed Aug 23, 2006 11:53 PM
I know that you can use metal and fiber glass to fill in big holes. is there any thing else that will work to fill in funky angles and pieces that are hidden from exhaust fumes??? anything besides duct tape, LOL
Post Post subject: Re: fillin in the blanks
Posted: Thu Aug 24, 2006 02:06 AM
Well there went my suggestion.
Takin' all the fun out of it.
Posted: Thu Aug 24, 2006 02:32 AM
I use just plain fiberglass in small odd spots.
speedtrash
speedtrash
Posted: Thu Aug 24, 2006 08:47 AM
hey i was gonna bondo my hood but would fiberglass be a good choice?
carpe diem
"sieze the carpe"
SandRacer
SandRacer
Posted: Thu Aug 24, 2006 05:17 PM
I'm not sure exactly where you are trying to seal up but I'm guessing that access might be an issue.
At your hardware store you can find a metal tape, about the width of duct tape, that is used to seal A/C and heating ducts. Then there is always the spray in expanding foam used to insulate cracks on homes.
1976 Baja Bug
saltyslug
saltyslug
Posted: Thu Aug 24, 2006 07:58 PM
that metal tape works pretty well as does the spray foam. I was hoping for something solid, but fiberglass might have to work.
I have a big hole where the rear tray used to be, and then a ton of little hols and areas where exhaust can leak in back thar.
SandRacer
SandRacer
Posted: Thu Aug 24, 2006 08:40 PM
How about forming a piece of thin metal like roof flashing and pop riveting or use sheet metal screws over the big hole? Then you could put small pieces of metal tape over the smaller holes and cover the whole area with spray in bed liner (aerosol type) to seal the real small holes.
1976 Baja Bug
saltyslug
saltyslug
Posted: Fri Aug 25, 2006 03:11 AM
I dunno that sounds pretty good actually. I just got through with all the welding for now. can you spary on the coating over the tape. I will take a pic in a few.
SandRacer
SandRacer
Posted: Fri Aug 25, 2006 03:22 AM
I didn't know you had a welder. Why not just tack in a patch section?
If the tape patches are small enough you ought to be ok with the spray. The tape is a pretty slick surface. Then again, you might just be better off sealing the smaller holes with JB Weld. After it cures you can rough up the surface. I used it in a few spots on the pan of my Manx and then shot bedliner over the pan.
1976 Baja Bug
Say10
Say10
Posted: Fri Aug 25, 2006 03:34 AM
Dont use the bed liner over the tape. You cant rough it up to spray the liner on.
