Visitors: 94
Total: 94
20: Event Calendar
22: Pictures
24: My Account
28: Event Calendar
39: Event Calendar
48: Home
55: Pictures
61: Event Calendar
62: Home
72: Home
77: My Account
Posted: Tue Jun 26, 2012 08:54 PM
its called a monkey face
Posted: Sat Jun 30, 2012 01:33 AM
SuburbanLegend wrote:
PS) Why do they always look like they're staring at you.....and they're not happy..... Shocked
SuburbanLegend
SuburbanLegend
Posted: Sun Mar 24, 2013 11:52 PM
So I decided a while back to re-do the rear suspension to a more traditional shock setup through the wheel wells. It was a pain to go back to the drawing board, but I'm happy with the ride now.
While I was at it, I added 2X2 tubular arms from Appletree and added some disc brakes.
Posted: Mon Mar 25, 2013 01:24 AM
That looks good. What brand of brakes did you use? Did you leave drums on the front
SuburbanLegend
SuburbanLegend
Posted: Mon Mar 25, 2013 06:39 AM
Those are EMPI brakes with the e-brake cables. The cables do fit even with the 2x2 arms. The rotors are the ones with some extra width to them. I'm using drums up front.
DirtDgr
DirtDgr
Posted: Mon Mar 25, 2013 03:17 PM
WOW! NICE! This is awsome.
SuburbanLegend
SuburbanLegend
Posted: Mon Mar 25, 2013 03:54 PM
Thank you....
Thank you...
I think my solution for a back seat also worked out good. I needed something that would fit in between the new shocks. Turns out a seat from a Jeep fits nicely. I found this one in a salvage yard and had it reupholstered to match.
These foam bolsters cover up the space between the seat and body nicely.
The back even folds down for some storage.
If anybody needs a good upholstery contact in the west valley, I'll give you her number....
SuburbanLegend
SuburbanLegend
Posted: Tue Mar 26, 2013 01:59 AM
So tell me what you think...I came up with an idea for a bump stop and a limit strap combined. I cut off the stock shock mounts/bump stop combo (this gets cut off most of the time to give clearance to longer shocks anyway) and had the idea to reverse them.
Notice this one is backwards.. It turns out that the stop will contact the trailing arm and the bolt hole may give me an option for a limit strap down the road.
We added a verticle brace to support the arms when contacted.
Generic bumpstop for now.
Last edited by SuburbanLegend on Tue Mar 26, 2013 02:04 AM; edited 1 times in total
SuburbanLegend
SuburbanLegend
Posted: Tue Mar 26, 2013 02:01 AM
I found the EMPI part number: 22-2927-F
There were a pain to bleed because the bleeder valve does not sit at the highest point unless you bleed them off the brackets. Just position the bleeder valve up top, bleed, then bolt them up.
Last edited by SuburbanLegend on Tue Mar 26, 2013 02:02 AM; edited 1 times in total
Posted: Tue Mar 26, 2013 03:40 AM
this is what I did. I had Crow bild me some straps but they dont give... when I put the Empi ones on they have some give to them... (I dont think they will last)
Posted: Tue Mar 26, 2013 03:44 AM
got more photos are at:
the bump stops are from a swing axle..
Posted: Wed Mar 27, 2013 03:18 AM
this is a better pic..
SuburbanLegend
SuburbanLegend
Posted: Wed Mar 27, 2013 05:58 AM
So I was getting a nasty wind slap inside the car when going over 45 MPH because of the ragtop opening. I realized it was likely due to the fact that I swapped out the pop-out windows in the quarters for stationary glass. Pop-outs would have let the wind pressure escape, which is probably why they were included on a ragtop from VW. Didn't think of that until it was too late.
My solution was to add this Yakima rack and wind fairing.
Works good, and gives me some more options down the road.
Last edited by SuburbanLegend on Wed Mar 27, 2013 10:00 PM; edited 1 times in total
SuburbanLegend
SuburbanLegend
Posted: Fri Apr 05, 2013 06:17 AM
So I think I'm done. Took it up to Crown King and got a little muddy.
Nothing major planned for a while. Just adjustments and fixing stuff that breaks.
tobiism
tobiism
Posted: Fri Apr 12, 2013 02:07 AM
I love it, you did a great job on it!!!
5 Admin_AzBaja 8364 Baja Bugs on Wiki need...
1569 mufasavnvmc 1059703 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 255467 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1223 FREE VW BAJA'S
0 Northmountainauto 2184 Shop Baja
