Latest: BlackIrish05009
Overall: 3574
Visitors: 135
Total: 135
19: Event Calendar
28: Home
38: Event Calendar
39: Home
44: Event Calendar
55: My Messages
85: Pictures
91: My Account
103: Home
113: My Account
SuburbanLegend
SuburbanLegend
Posted: Sat Jan 10, 2009 07:46 AM
perrib wrote:
It has come a long way. I with you on the cut and buff I only do it if I have to.
Yeah, unfortunately I haven't figured out how to spray clearcoat like the factory. Laughing
SuburbanLegend
SuburbanLegend
Posted: Sat Jan 10, 2009 07:53 AM
az350x wrote:
That thing's looking GOOD! I like the color!
You got my attention with that rag conversion. I'd LOVE to have a ragtop conversion in mine someday.
Cool. Can't wait to see the reassembly!
Thanks. The ragtop took some guts, and I'm nervous about the quality of the ragtop mechanism, so we'll see. If the mechanism is no good, I may just rivet some snaps around the frame and make a snap-on covering out of canvas or vinyl that could be removed entirely. I wouldn't be very waterproof, but I think I gave that up when I cut the hole in the roof. Cool
Posted: Sat Jan 10, 2009 05:27 PM
The early street beat full length rag conversions (circa 1992) required patience when opening and closing them. Once you get some dirt on the paint and rough spots in the clear will move to the back ground.
SuburbanLegend
SuburbanLegend
Posted: Tue Mar 31, 2009 06:32 AM
So I finally got the body back on the pan. It's starting to look like a car again. Now what Question
Posted: Tue Mar 31, 2009 06:35 AM
ITS SOOOOOO, SHINY! LOOK,N GOOD!
Grunt-0341
Grunt-0341
Posted: Wed Apr 01, 2009 12:34 AM
The car looks great! I can't wait to see the finished product. Keep us posted.
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Wed Apr 01, 2009 04:00 AM
now it is a street baja not a baja bug
lol
nice and shiinny
definetly dont want to reck that pain lol
kyle_pc_75
kyle_pc_75
Posted: Wed Apr 01, 2009 04:07 AM
Great looking car! I have to ask...why Carbon Footprint? The CF you'll leave by restoring and driving that VW is far smaller than what it would take to even manufacture a silly hybrid. Very Happy
Kyle
SuburbanLegend
SuburbanLegend
Posted: Wed Apr 01, 2009 05:30 AM
Kyle
Exactly! I thought I could at least make it look and sound as ANTI-Hybrid as possible. It's my way of thumbing my nose at the whole Carbon politics and "Global Warming" propoganda. (Not a big Al Gore fan..) I can't wait to get out and burn some fossil fuels! Twisted Evil
Last edited by SuburbanLegend on Thu Jun 04, 2009 02:46 PM; edited 1 times in total
Posted: Wed Apr 01, 2009 06:32 PM
Looks great!!
SuburbanLegend
SuburbanLegend
Posted: Sat Jun 20, 2009 04:38 AM
I had come to a crossroads about what direction to go with my engine. The idea of power and reliability got me thinking about a water-cooled conversion. I finally took the plunge and decided on the GM Ecotec 2.2 for its compact, lightweight design, plentiful parts, and stock power. Hopefully this doesn't alienate me from the air-cooled purists out there..(Remember, I own and drive a stock '67 Sedan also.. Very Happy )
I found a used engine from Precision Auto parts in Phx from an 05 Saturn Ion, with allegedly only 12,000 miles. I trailered the block out to Turnkey Engine Supply in Oceanside, CA. They hooked it up, swapped out a few odds and ends including the adapter plate, computer and harness, and got it running and ready to hook up in just 1 day!
This should also give me the option to add a lot more power if needed (turbo or supercharger?) It should give about 170 hp and 155 ft/lb torque in it's stock form. But for now, I'll just be happy when it's running.
First of all, it doesn't quite fit behind the stock firewall, so I had to cut a hole about the size of a piece of paper. I will need to make a removable box or something to close this off.
After clearancing a few more things, It mounted up nice!
Without the opening, it would set right against the firewall. A removable box or door should give access.
One of the advantages of the Ecotec will be ground clearance. It doesn't sit any lower than the stock frame horns...much higher than a Subaru or even a stock VW with an oil sump. The block is aluminum, so the additional weight should be nominal.
Now I just need to figure out where to mount the radiator...and about a million other things.... Confused
Posted: Sat Jun 20, 2009 05:44 AM
that is sick man
cant wait to see you finish it
Posted: Mon Oct 05, 2009 01:14 AM
Very very nice! Cool
I'm 50-50 on the power plant as far as non VW vs. VW. Some ways I prefer VW power 'cause it's easy to work on, a lot less to break down out on the trail, less maintenance and so on.
That said, for close to the same weight/size, your adding quite a bit more HP to the wheels when you throw something like a Subaru, Ford or GM engine in. So, to each his own. Heck, I've thought about building a Baja and throwing a diesel Rabbit engine on and brewing my own fuel.
In any event. Looking good. I did drool a bit scrolling through the pic's.
Any updates on the project?
Posted: Tue Oct 06, 2009 05:17 AM
I will say that you have more maintenace with the VW engine. Most of the modern engines do not need the up keep like a VW engine does.
SuburbanLegend
SuburbanLegend
Posted: Tue Oct 06, 2009 07:35 AM
So far, the hardest parts have been figuring out all the modifications needed for simple things, like a throttle cable that mounts to the ecotec, where to mount the muffler, how to add a rear engine mount, where to route another fuel line for the fuel injection, where the air intake can be to not interfere with the engine cage, putting a radiator assy together that will work, getting the right gauge sending units.. and a thousand other little things that VW engines don't have to worry about. I'm still optimistic it will be worth it in the long run.
An update should be coming w/in the next couple weeks. I'm having the roll-cage finished as well as the front and rear bumpers.
I'll also have a widened ball joint beam from Bugzilla to show off, so stay tuned.
4 Admin_AzBaja 5811 Baja Bugs on Wiki need...
1568 mufasavnvmc 913785 Re: what did you do to...
285 MusicManiac 221048 Re: Baja sightings
0 Northmountainauto 424 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1809 Baja hiding in Chandle...
