Visitors: 171
Total: 171
77: My Account
97: Pictures
107: My Account
109: Home
123: Home
158: My Account
162: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- super body question
super body question
wazhier
wazhier
Post Post subject: super body question
Posted: Sun Dec 14, 2008 07:53 PM
my buddy is wanting to replace his standered bug body. and was wondering if a vert super beatle body minus the front end will bolt to the pan?
Post Post subject: Re: super body question
Posted: Sun Dec 14, 2008 10:03 PM
Yes
Posted: Sun Dec 14, 2008 11:10 PM
It will bolt on but the hump on the front of the pan is wider on a super, so the 4 front 10mm (17mm head) bolts wont line up unless you oblong the holes in the pan.
wazhier
wazhier
Posted: Mon Dec 15, 2008 01:58 AM
cool thanx
neon99
neon99
Posted: Tue Dec 16, 2008 06:22 AM
If the hump is wider on the super body will there be a gap between the sedan pan and super body at the hump?
Posted: Tue Dec 16, 2008 04:31 PM
I should have said thicker, not wider. its about 1 1/8 thick on a standard bug, and 1 1/4 on a super bug. Not much, but enough to give you fits on a body swap. Cool
25 Kreed 24779 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 7402 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2018 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts Projects and Builds my 72 super project 2 vtbaja 2739 my 72 super project
 Tue Jan 21, 2014 11:34 PM
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2504 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
