Latest: BlackIrish05009
Overall: 3574
Visitors: 142
Total: 142
02: Pictures
03: Event Calendar
06: Pictures
12: Event Calendar
25: My Account
35: My Account
45: Event Calendar
63: Event Calendar
67: Event Calendar
71: Event Calendar
87: Event Calendar
103: Event Calendar
104: Event Calendar
111: Event Calendar
135: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Heater Idea
Heater Idea
Thuff
Thuff
Post Post subject: Heater Idea
Posted: Sun Nov 09, 2008 02:41 AM
Even though i have been considering a Pinto or toyota engine for my baja. Has anyone ever used an oil cooler for a heater? I bet it wouldn't be hard to rig up to have blow in the car when you need heat and blow out of the car when you don't. It may take a while to heat up, but hey stock heaters aren't really speedy either.
Post Post subject: Re: Heater Idea
Posted: Wed Nov 12, 2008 03:57 AM
I have. Mount in in a box under the rear seat blow the air into the heater ducts and you can also have a defroster.
SuburbanLegend
SuburbanLegend
Posted: Wed Nov 12, 2008 05:24 AM
I've heard of this being done. Anybody have some pictures to help? Question
chrispy56
chrispy56
Posted: Wed Nov 12, 2008 06:08 AM
i have thought of mounting a second cooler in the car connected in one circuit using a few t-fittings and 12v operated valves to direct the hot oil to either the cooler in the passenger compartment for heating or to the exterior one for cooling. with a small fan behind it and good seal (widows, doors, dash, etc.) i think it would work good enough for me in CA. although it may be too much work for the oil pump
Posted: Wed Nov 12, 2008 10:21 AM
I have a pinto, but I would think you could do the same. I just run a T-Valve and electric fan on my heater. summer I turn it to bypass winter I turn it too heat. If I want hot air I turn on the elctric fan. evan in the summer if the heater is on and the fan is not running the heater will not put that much heat into the car with out the help of the electric fan.
No new posts Projects and Builds Cool little idea 6 Yummi 4061 Re: Cool little idea
 Sat Dec 22, 2012 04:09 PM
Lucky7-11 View latest post
No new posts Projects and Builds i have an idea... 2 creepercritter 2191 i have an idea...
 Fri Sep 23, 2011 01:54 AM
creepercritter View latest post
No new posts VW Volkswagen & Baja Bug General Discussion heater tubes 2 cyberjaw4 1386 heater tubes
 Mon Feb 16, 2009 10:13 AM
cyberjaw4 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Uncut street baja idea 2 custom1106 2635 Re: Uncut street baja ...
 Mon Oct 13, 2008 02:34 AM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cargo area and heater ?tinnels? replacement. 4 WaBaja 2033 Re: Cargo area and hea...
 Wed Apr 16, 2008 11:30 PM
WaBaja View latest post
