Latest: xbluegto
Overall: 3573
Visitors: 180
Total: 180
22: Pictures
26: Event Calendar
45: Pictures
53: Pictures
58: Home
59: Event Calendar
63: Event Calendar
67: Pictures
79: Pictures
107: Home
133: Event Calendar
136: Pictures
142: My Account
144: Pictures
152: Pictures
161: Pictures
162: Baja Forums
166: Baja Forums
173: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Hello
Hello
Post new topic This topic is locked: you cannot edit posts or make replies. Printer Friendly Page
AteElmo
AteElmo
Post Post subject: Hello
Posted: Wed Nov 12, 2008 08:58 AM
I'm new in here and the vw baja world
I'm about step in the baja world
like know if this baja bug sounds good please
let me know what your opinions are!
The Vw has been gone through by (x). new 1600 duel port, new carb pict 34,new dist vac advance electronic . new starter, new windshield. Stock 74 tins with thermostat. And 12 volt generator, hi out put fan. Skid plate. heater, and ac. little swampy. New wheel cyl ,rear drums, wheel bearings. picked out the best doors available. with wind wings and window cranks that are geared. Dont strip. new tires. new clutch, cables, jamar turning brake control. rear fiberglass bench. painless wiring system, 4Hella hi intensity lights. 8 gal fuel cell. pioneer 200watt amp, sony cd. 12inch bosse woffers. New tie rods. bump stops ft, new speed o cable. new rear coil over shocks, kyb gas shock frt. undercoated, off road bed liner paint. To protect it off roading. Did not spend a fortune on paint that gets scratched easily. new interstate battery, v do, trans axle is a swing axle. no problems. 4 speed. this Baja bug is very road worthy and off road ready. got 5k in parts over the years in it plus the 17oo I paid for it. I brought the engine back to stock intake and exhaust and tins so it would be reliable. It is. Confused
Copied from blogs - add comments there.
AteElmo
