Visitors: 218
Total: 218
10: My Account
72: Event Calendar
73: Event Calendar
146: Home
160: Event Calendar
162: Event Calendar
163: Event Calendar
168: Baja Forums
172: Baja Forums
177: Baja Forums
182: Baja Forums
184: Baja Forums
186: Baja Forums
187: Baja Forums
189: Baja Forums
194: My Account
195: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: Baja Forums
207: Home
208: Home
209: Baja Forums
210: Baja Forums
212: Baja Forums
213: AMAZON.com
214: AMAZON.com
217: Baja Forums
218: Baja Forums
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Thu Mar 12, 2009 12:54 PM
Post Post subject: Re: Navy nuke building a baja for Play/Race
Posted: Tue Jan 27, 2009 06:25 AM
I happen to know of another,that is that clean!! Wink look,n good,,looks like you and i are work,n on the same thing!
navynuke
navynuke
Post Post subject: Navy nuke building a baja for Play/Race
Posted: Tue Jan 27, 2009 07:37 AM
only clean because I've never had it running. won't stay that way I'm sure.
Posted: Wed Jan 28, 2009 03:06 AM
Laughing After seeing your metal door panels and your speakers, I keep thinking the same thing- you're gonna need a bigger set of speakers!
(I've got a metal interior like that, and it'd take a LOUD stereo to be heard over all the racket inside the car!)
Shocked
navynuke
navynuke
Posted: Wed Jan 28, 2009 05:35 AM
we will see. the speakers in the box were 15 bucks. its a place to start. and may make changes as needed
navynuke
navynuke
Posted: Wed Jan 28, 2009 11:20 PM
awwww bugger, filled the coolant system last week, and the level dropped a fair amount. thats odd, no signs of water on the outside dripping anywhere, so pulled the oil drain bolt, and got this
anyone familiar with these engines know if its more likely a head gasket, or cracked head or block, or something else?????
also fighting a messed up brake system. any tips on bending the hard lines to get them into place?
Posted: Thu Jan 29, 2009 09:54 PM
Unfortunately will have to pull the head to inspect.
Do you have a tubing bender? If not Daryll can fix you up.
acousticrawk
acousticrawk
Posted: Thu Jan 29, 2009 10:36 PM
suck a duck. not much worse than finding the milk shake, cause then you know you in for some work. i guess thats what nice about air colled engines... no chance of coolant getting in your oil and eating you bearings... maybe a rebuild is in order since youll be there? very interested to know what you do. goodluck, and looks like it will be a pretty sick little whip when your done.
Bring'n West Coast Baja Bug Madness to the Easy East Coast!
navynuke
navynuke
Posted: Thu Jan 29, 2009 10:42 PM
well found another motor on craigslist for 200, just gonna swap that in, and then look into this to see what it will take. anyone interested in an adapater for a ford 2.3 to a VW? the guy has one.
Ken
acousticrawk
acousticrawk
Posted: Thu Jan 29, 2009 10:44 PM
yeah! i would be! PM me!!
navynuke
navynuke
Posted: Fri Jan 30, 2009 12:02 AM
pulled the header and valve cover today, signs of milkshake and rust on the valve train, and the cam is toast.
look for yourselves.
Posted: Fri Jan 30, 2009 01:35 AM
2.3 Fords are notorious for cracking beween the intake and exhaust seats. Thats what I would look at first.
acousticrawk
acousticrawk
Posted: Fri Jan 30, 2009 01:23 PM
i have a question for you... how common is it that the 2.3 will blow a HG or something "screaming" (<haha, i knwo right?) across the desert? how reliable is it?
Posted: Fri Jan 30, 2009 09:22 PM
They can be very reliable stock and be built up to crazy power. Talk to Madman74 aka Shawn, he is a 2.3 guru.
acousticrawk
acousticrawk
Posted: Fri Jan 30, 2009 09:35 PM
right on, thanks!
navynuke
navynuke
Posted: Sat Jan 31, 2009 01:52 AM
well I bought a new motor today, and its not a 2.3......
its the older german 2.0 from a 72 pinto.
header looks like it will swap, blocks look the same as far as bolting up, taking a 160 dollar gamble that I can make this work, or frankenstein them together.
but I'm open to any advice ect.
the older one has a smaller 2 barrel carb, not sure if the motorcraft intake setup is worth swapping, or what.
thats the new motor. gonna be putting it on the stand and cleaning it up some tomorrow before the bugfest.
see you guys tomorrow
1 2 3 4 5 6 7 8 9
5 Admin_AzBaja 6857 Baja Bugs on Wiki need...
1568 mufasavnvmc 1001462 Re: what did you do to...
285 MusicManiac 241872 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 62 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1330 Re: Had to go play in ...
