Visitors: 110
Total: 110
05: Event Calendar
13: Pictures
21: Pictures
31: Pictures
96: Event Calendar
1 2 3 4 5 6 7 8 9
The following users give thanks for this topic Anonymous - Thu Mar 12, 2009 12:54 PM
navynuke
navynuke
Post Post subject: Navy nuke building a baja for Play/Race
Posted: Sat Nov 08, 2008 04:16 AM
Ok, guess I'll post up what I have to start with.
65 bug shell
3 rib bus trans, Ford 2.3 out of a pinto or some such thing with a Holly carb.
Widened Linkpin beam up front, with towers, Sacco Rack, I think, full cage front to rear, Race Trim seats, 16 gallon fuel cell, Fox shocks for the rear(need to be rebuilt) rear is otherwise stock setup, but not sure what size torisions are in it.
Some pics
fox shocks
The interior is down to bare metal now, needed some welding/rust repair. you can see my terrible body repair, but it'll work.
I need to get the seat moved back an inch or 2, and all the tabs for seat belts, as fuel cell mount, and a cross bar in the main hoop to make the cage legal for racing I believe. not sure if I missed anything else in that.
gonna put a bare aluminum dash panel in after I paint it, and rewire the whole car. New Crow 5 point harness's are in the mail now.
Now is where I need some advice.
I need headlights, but not a lot of money, any advice?
I have a straight header off the ford 2.3, I need some exhaust ideas, I'll post up better pics tomorrow after I get off work, but looks kinda tight.
I need to get an airfilter setup, the one on the car works, but its pretty beat up, and ungainly, what do you guys recomend for air filters? build one of the pods with a cone filter inside it?
I have 4 lug rims in the back, and wide 5 up front. want to go to disc brakes in the front, should I just leave the rims be till I have the money for that and do 4 lug dics? or some other idea?
any other areas where you might think I'll have an issue?
thanks a ton, and I'll get some fresh pics up in the morning.
Post Post subject: Re: Navy nuke building a baja for Play/Race
Posted: Sat Nov 08, 2008 04:20 AM
looks like a good builder.
klwdesigns
klwdesigns
Posted: Sat Nov 08, 2008 05:43 AM
do you already have disc brakes in the rear? I've read rear braking is more important in a baja bug than front breaking, on the dirt anyway.
not sure what you're looking for in headlights.
or check this www.azbaja.com/Forums/...=4423.html
search alot of pics for airfilter ideas. there are so many cool ideas I've seen.
Posted: Sat Nov 08, 2008 04:13 PM
As far as lights go, harbor freight has some $10 kc style lights.
navynuke
navynuke
Posted: Sun Nov 09, 2008 12:51 AM
air filter I'm having problems with is because holley carbs have that center stud to hold the filter down. most of the canister shielded ones I've seen clamp on to VW style carbs with a hose clamp at the top.
hmm, eng. problems are fun.
Interior is about 80% bare metal, I'll finish up whats left on my days off this week, and contact bugzyla aobut the cage stuff.
navynuke
navynuke
Posted: Mon Nov 10, 2008 11:52 PM
dropped off at bugzylla today to get the cage setup the way I want.
should be done in a couple days there.
and I guess a supertrap clamp on setup is gonna work for quieting down the exhaust.
wohoo progress
Posted: Tue Nov 11, 2008 06:19 AM
wohoo progress
The 3" SuperTrapp will fit into the Header you have now. I use 24 Disc's normal is 12 Discs. Look for center Nut. It is built to slide inside the header you have, you might need to give superTrapp a call and ask for it, I can not see it on the web site but it looks like this with out the extension.
www.supertrapp.com/pro...p?CatID=35
en.wikipedia.org/wiki/Paul_Moller SuperTrapp maker odd info.
meangreen
meangreen
Posted: Tue Nov 11, 2008 07:10 AM
az,where do ya'll get a header like that ? how much and mite they have it for my chevy swap ? sorry for jacking your thread navynuke....
Posted: Tue Nov 11, 2008 11:36 AM
www.esslingeracing.com/
and no you can not get one for a chevy... Rolling Eyes
navynuke
navynuke
Posted: Tue Nov 11, 2008 09:40 PM
thanks, I'll be checking out chirco's store next weekend, if they don't have something, i'll contact supertrap directly. thanks for the help
navynuke
navynuke
Posted: Fri Nov 14, 2008 03:29 AM
Just picked up from Bugzyla, new cage stuff looks good, I'll get some pics up tomorrow.
hope to get the interior prep finished so I can build a paint booth in the garage next week.
anyone have a harbor freight HVLP type setup I can rent?
Ken
navynuke
navynuke
Posted: Sat Nov 15, 2008 03:38 AM
You can see the fuel cell behind the seats, added the bar behind the seat with seatbelt tabs, and the other tabs for my crow harnesses.
I'll put both seats in and harness's for a test fit over the next few days I have off and get some pics up.
Posted: Sat Nov 15, 2008 04:04 AM
NICE start navynuke! Seems your on one heck of a start.
How many folks have the rear as open as yours? Never seen that outside full Baja/Race.
navynuke
navynuke
Posted: Sat Nov 15, 2008 05:17 PM
I think this was originally put together as more race than street.
might work on closing in some of it later, but first gonna get out and see how dusty it gets inside.
navynuke
navynuke
Posted: Thu Nov 20, 2008 07:05 AM
got a supertrap today
just need to weld it onto the header.
interior is almost done, just need to fix my compressor now to sandblast the last bit of paint out
1 2 3 4 5 6 7 8 9
4 Admin_AzBaja 5576 Baja Bugs on Wiki need...
1568 mufasavnvmc 889508 Re: what did you do to...
285 MusicManiac 215890 Re: Baja sightings
0 Northmountainauto 46 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1098 Baja hiding in Chandle...
