Visitors: 104
Total: 104
15: Pictures
47: Event Calendar
58: Event Calendar
60: Event Calendar
74: Event Calendar
76: Event Calendar
79: Event Calendar
103: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 1776, 1835 or 1600 w/ turbo
nube_w_1970baja
nube_w_1970baja
Post Post subject: 1776, 1835 or 1600 w/ turbo
Posted: Sun Oct 26, 2008 07:49 PM
i'm planning on getting a new motor in probably about a year. i've narrowed it down to these sizes, but still not sure of all the ups and downs...
if you could help me out, i'ld really aprreciate it.
Post Post subject: Re: 1776, 1835 or 1600 w/ turbo
Posted: Sun Oct 26, 2008 09:34 PM
For off road I would rather have a 2165, 2180, 2332, 2275 with an Engle 110 cam, VZ 25, VZ 30 or FK 7, cam and single carb. That said a junk yard 1835 turbo will walk all of the afore mentioned engines. I feel using a turbo engine off road with out EFI and a a knock sensor the chance of severe engine damage due to lean running out weighs the power advantage. If you go 1835 use the thick wall cylinder kit form AA.
Thuff
Thuff
Posted: Mon Oct 27, 2008 08:10 AM
I like turbos, If you have money to burn they are the way i think. I like strokers too. I think for off road strokers are better. For the dunes and street i like the turbo.
I had a buddy with an auto stick and a turboed 1776 and that was the best set up I have seen yet. Seemed strange but they worked well together.
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 2541 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds FABINC 5-1600 Build
New Baja Build (updates monthly)
127 wideopenmotorsports 115369 FABINC 5-1600 Build
 Fri Feb 14, 2014 06:25 PM
No new posts VW Volkswagen & Baja Bug General Discussion baja / turbo / turning breaks,
info needed.
11 Jc26 6650 baja / turbo / turning...
 Tue Jul 19, 2011 04:38 PM
Jc26 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Mazda 13b Turbo Conversion 2 logan44 3038 Mazda 13b Turbo Conver...
 Tue Jun 21, 2011 09:00 PM
HuggingxCorners View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Instructions to install 002 trans. in 1969 1600 Baja?J 12 glenf 9342 Re: Instructions to in...
 Fri Apr 24, 2009 06:45 PM
DONT View latest post
