Latest: ecthemc
Overall: 3567
Visitors: 143
Total: 143
02: Event Calendar
52: Event Calendar
72: Event Calendar
79: Event Calendar
89: Event Calendar
111: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Pre-Trip Inspection
Pre-Trip Inspection
Post Post subject: Pre-Trip Inspection
Posted: Thu Sep 25, 2008 03:47 AM
This should be a really good topic, perhaps we can even make a sticky when we get to the end of it. Let's comprise a comprehensive list of things that we need to check on our cars before we leave for a run. When you add something, cut and paste from the list before and add yours to the end of it. Cool? I'll start:
- Lug nut torque
- CV bolt torque
- Steering wheel bolt torque (mine likes to loosen up)
- Tire pressure
- Oil Level
- Towbar bracket welds
- Shock bolt torque
- Link pin nuts
- Steering box/tie rod nuts
- Window cranks/door handles (mine like to fall off when I'm bouncing around)
- Lube front end
- Emergency kit contents
- Check for abnormal oil leaks (notice I said "abnormal"?)
OK...
That's a start. Add yours. Don't forget the cut and paste!
Post Post subject: Re: Pre-Trip Inspection
Posted: Fri Sep 26, 2008 08:43 AM
Does anyone around here ever get out?
Here's an updated list we composed on STF....
- Lug nut torque
- CV bolt torque
- Tire pressure including spare tire
- Oil Level
- Shock bolt torque
- Link pin nuts
- Lube front end
- Nuts on the thru-rods (for the coil over guys)
- axle nuts
- adjust brakes (for us still with stock brakes)
- check fuel lines.
- Bolts on the carbs.
- Carb linkage.
- Oil lines,
- turbo bolts,
- shift linkage.
- drum nut check.
- Good fire extinguisher
- Lots of tools , fuel quality check (turbo thing)
- Smell the oil for fuel wash (turbo thing)
- Check ignition wires.
- Light check - head, tail, turn, brake
- Trailing arm pivot bolts
- Front wheel bearing play
- CB, "Radio Check"
- Clean & oil air filters and prefilters
- Hydraulic brake/clutch fluid level
No new posts Events and Get Togethers World Wide Ghost Town off road trip! March 16th 12 Dalton 5386 Re: Ghost Town off roa...
 Mon Mar 18, 2013 03:31 PM
No new posts VW Volkswagen & Baja Bug General Discussion wickenberg to yarnell trip 3 64vwbug 2040 wickenberg to yarnell ...
 Mon May 07, 2012 11:04 PM
No new posts Events and Get Togethers World Wide Over night exploring trip just east of the valley. 6 Ejbbal21 2739 Re: Over night explori...
 Sat Feb 25, 2012 01:12 AM
No new posts Events and Get Togethers World Wide dec. 3, 11...4 peaks road day trip to reno pass....
day trip over 4 peaks heading to reno pass then home.
2 ikill6453 3973 dec. 3, 11...4 peaks r...
 Mon Dec 12, 2011 10:39 AM
No new posts Events and Get Togethers World Wide AzVC Presidents Day offroad camping trip.
20 perrib 13375 Re: AzVC Presidents Da...
 Wed Feb 23, 2011 01:38 AM
ikill6453 View latest post
